04-19-2015, 17:36 | #1 (permalink) |
No Life Poster Join Date: Jan 2012
Member: 1713296 Status: Offline Thanks Meter: 67 | Q Mobile R1000 file needed , set dead after format[File Inside] Problem was its password which customer have been forgotten, By mistake I did not make its backup and do format , now phone is dead , I follow instruction from here , select backup file(which was taken after format) but no luck, please any member share file of this phone, http://forum.gsmhosting.com/vbb/f723...4/#post9943948 Code: Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM109), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Please change Boot or reduce Baudrate, try it again. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 1.50 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM109), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00EF006000170000 Flash Type: SF_W25Q64DW Size:0x800000(8MB) >>Set to Factory successfully. Thanks and regards |
04-19-2015, 18:54 | #2 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | WRITE THIS FILE WITH VOLCANO 2.7.2 OR LATEST 3.0.0 MOCOR_12C.W13.04.05_Release_20150304_174442_FullFl ash AFTER WRITE TURN PHONE ON (PRESS PWR BUTTON 2-3 MINUTES) IF NOT WORK SELECT FILE AND DO FORMAT. IF ANY EROR POST RESULTS WITH SCREENSHOT NOT LOGS Quote:
The Following User Says Thank You to masterRt1994 For This Useful Post: |
04-19-2015, 19:05 | #3 (permalink) | |
No Life Poster Join Date: Sep 2013 Location: India
Member: 2030192 Status: Offline Thanks Meter: 1,334 | Quote:
Brother MAsterRt1994 u doing good work but before please tell it to the member always post on correct section | |
The Following User Says Thank You to blacky199 For This Useful Post: |
04-20-2015, 08:36 | #4 (permalink) | |
Member: 1713296 Status: Offline Thanks Meter: 67 | Quote:
Thanks master you save me, thanks a lot for file sharing, @blacky199 Did I post in wrong section? | |
