01-30-2015, 14:13 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | need help mtk6582!!! |
The Following 2 Users Say Thank You to masterRt1994 For This Useful Post: |
01-30-2015, 19:06 | #3 (permalink) |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Hello try on using modified cable ,press download button of flash tool , connect cable phone to pc , may be it will work . |
The Following User Says Thank You to ..:\\lucky//:.. For This Useful Post: |
01-30-2015, 23:23 | #5 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | u have already a backup file so just try this first in mtk tab select proper boot file tick "format"--"run"--in format tab select "full flash" and click on "OK" Not Auto..if u success in this step then try to flash phone in android tab with your backup file,, first try on fac if not work just write bin file personally i revive many phones in these kind of situations on this way when phone flashed with wrong firmware or mmc partition are corrupt or phone flashed with wrong preloader and volacano ignore flashing the phone like its just stop after download boot.. so just try this procedure maybe its work for u..good luck friend |
The Following User Says Thank You to danishalnoor For This Useful Post: |
01-31-2015, 09:58 | #6 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Lahore
Member: 2093017 Status: Offline Sonork: 100.1650959 Thanks Meter: 117 | brother try with new charge battery or charge it after that change pc and choose 2.8.0 version and then flash with android tool and then your problem solved if not i have working file need tell me |
