04-10-2014, 09:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2139591 Status: Offline Thanks Meter: 78 | Qmobile connects only Mass Storage I mean if it can be connected with main cable like Dragon. then it is ok, but how ? |
04-10-2014, 09:32 | #5 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Quote:
its very simple hold call butoon and insert usb cable in volcano untick auto detect check in device manger and set com port after tick on imei tool and press run and do change imei BR Qaisar Mahmood | |
04-10-2014, 10:07 | #7 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Try to detect First ... Set pinout .. Now remove volcano main cable or power cable .. Power on the phone with buttery .. Now connect only Volcano main cable ... No need to use volcano box power cable .. A screen come on phone ..Select com port in phone .. Now see the device manager & see the phone port number .. Go to Volcano mtk tab .. Enable IMEI ..[alt+ctrl+i] press ... See the pic .. After select port & fill the imei number Do White IMEI .. Try it & posr result ... Br, AniAXN |
04-10-2014, 10:22 | #8 (permalink) |
Member: 2139591 Status: Offline Thanks Meter: 78 | You Guys don't try to understand me. i know all the procedure for repairing but it doesn't detect com prot no. How to enable in Qmobile E880. It can be easily repaired with Dragon, but I want to know the procedure in Volcano |
04-10-2014, 18:54 | #11 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | do enable imei option click on imei write (at mode) and press start button in new window put imei and in post option select usb option and press write imei put usb cable in phone if still not show imei ok then keep plug usb cable in phone and power on the phone untill say imei ok if still problem then search flash file and write on it |
