Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 10-09-2012, 11:59   #16 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
Originally Posted by umesh gaba View Post
same as before .
not writing flash
Old 10-09-2012, 12:32   #17 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
when get info its right :
Detection initiated...
Vcc: 9
Gnd: 2
Analyzing D+ and D-...
D+ = 6, D- = 8
Detection D+/D- with 1,67 seconds.
Continue to detect BOOT pin...
Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 5
Setting...
Find USB device:SCI USB2Serial (COM29), (VID_1782&PID_4D00)
Pinouts setting complete!
Internal version: SPRD3
Boot downloaded.
Start boot please wait a moment....
Spreadtrum Boot Block version 1.1
Boot downloaded.
CPU TYPE:SC6800H [68000000]
Flash ID: 00200036
Flash Type:[ST] NAND512
FLASH LEN:0x4000000
Phone imei lists.
IMEI1:352643048295555
IMEI2:352643048295563
IMEI3:358570010103893
Read Info finish.
but when go to flash it's stoped
please whaty i can do to revive this phone because costumre need phone as before
Old 10-09-2012, 13:17   #18 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
rebuild backup flash succed
but phone dont power
ther is questio :
why phone have to sim and show three imie ?
Old 10-09-2012, 14:06   #19 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 6,087
write backup again with baun rate 230400
Old 10-09-2012, 14:34   #20 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
phone when connect to dc power supply
show 0.09 v.
what's mean this
Old 10-09-2012, 14:34   #21 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
show 0.09 v.
what's mean this
Old 10-09-2012, 15:31   #22 (permalink)
Member: 1792140
Thanks Meter: 6,087
don't worry brother if power supply show on 9 amp
if write backup again with baun rate 230400 your problem solve
Old 10-09-2012, 17:29   #23 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
am not undrested this phone .
read flash ok.
write flash not olways stoped .
Old 10-10-2012, 10:45   #24 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
mybe it's hard problem
because when i put phone in charger whith batrry phone heats.
any idea
Old 10-10-2012, 11:01   #25 (permalink)
Member: 226457
Sonork: No more used
Thanks Meter: 14,934
@lahdache
Select Start Address 100000 or Start Address 400000
then Write Backup 100% Working Method.
6800h writing 0
See this
Also See this Solved Link
http://forum.gsmhosting.com/vbb/f723...olved-1548599/
Qaisar Mahmood
Old 10-10-2012, 11:10   #26 (permalink)
Member: 1792140
Thanks Meter: 6,087
write backup again with baud rate 230400 and start address 100000 or 400000
Old 10-10-2012, 11:12   #27 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
cant write at baun rate 230400.
olways stop in write flash
Old 10-10-2012, 15:22   #28 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
this two baud rate ( 460800 and 230400 ) cant work when writin flash.
need explain team.
ragard
Old 03-31-2013, 18:57   #29 (permalink)
Member: 218246
Thanks Meter: 58
need help
your flash file size
if 66mb try this
ROKEA R3850 SPD (HYUNDAI) HY27XS08121A (66MB).rar
I need urgently flash file for s3850 with this statestic:
Boot downloaded.
Boot downloaded.
CPU TYPE:[68030000]
Flash ID: 009800A1
Flash Type:[TOSHIBA] TY9AOAA111286KC
FLASH LEN:0x8000000
Flash name:
MOCOR_10A.W11.42_P4_Release_20130331_172842_FullFl ash.bin, size: 132 M.
For who can help thanks in advance .............
Old 04-01-2013, 11:25   #30 (permalink)
Member: 218246
Thanks Meter: 58
the same thing
-select spd cpu
-tick 6800h
-load flash file
- 100000 start address
-tick write flash
-run
-wait until finish
-done
TRY AND POST RESULT
Umesh gaba
even i do all that I have the same problem :
Boot downloaded.
Boot downloaded.
Writing...(0)
Please input any number not 0 at the Start Address and try again
Please change Boot or reduce Baudrate, try it again.
>>Ready to read/write again, please remove the power supply clip or battery and then re-loaded it.
Page generated in 0.21083 seconds with 8 queries
