03-21-2015, 15:35 | #2 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Need to Press & Hold Boot Key , Or Short Tx TP With ground , Also Check That You Have Selected Correct Boot , What Is Your OS 32bit Or 64Bit ? |
03-21-2015, 15:42 | #3 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india. kerala.
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | 32 bit .which is boot key???press power key and voliam down when conect??? its format or need full flash for solve problanm?? |
03-21-2015, 16:51 | #5 (permalink) |
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | yes.ur correct .its mtk 6572a .bvut how can conect .??not detect normal; usb cable via press voliam down press ..another solution?? |
03-22-2015, 07:54 | #7 (permalink) |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | manually make your volcano cable - a usb cable ! go to detect tab. manually drag and drop pinouts as given - Code: pin1 = vcc pin2 = usb d- pin3 = usb d+ pin5 = gnd press "set pinouts" button now work from android tab tick "read flash" press START then insert this manual usb cable in powered off mobile with battery inserted post report. bR. |
