Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 01-12-2014, 20:39   #1 (permalink)
Member: 1215266
Thanks Meter: 129
s7562 mtk6575 after flashing dead
i have samsung make backup before duos s7562 mtk6575 file size 1.75gb butt after flashing dead although using latest version. sugest any solution.
now not coonect with volcano
Old 01-12-2014, 21:21   #2 (permalink)
snak2's Avatar
Member: 1510086
Thanks Meter: 78
s7562 if og sam... use other sam..flaser like z..x ......s...t .or use og tool :P
Old 01-12-2014, 21:43   #3 (permalink)
Member: 1215266
Thanks Meter: 129
same problem this back Backup other sam Enter mt6575_kpd_gpio_set.bin
not connect with box volcano bro how to re flash cable volcano ?? now this samsung not coonect with pc
Old 01-12-2014, 21:48   #4 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
Brother I thik you write wrong flash file ...
If phone not connect to usb or no boot in your phone ..
Open your phone ..& search the pin of "kolo" "colo" like rx tx point.
& short this pin to ground (gnd)..& connect to usb ..
in this way your phone will must connect to pc ..
Now write a good or proper file to solve it ....
If face any problem Post some screen shot ...for better support. .
Br,
AniAXN
The Following User Says Thank You to AniAxn For This Useful Post:
Old 01-12-2014, 22:18   #5 (permalink)
Member: 1215266
Thanks Meter: 129
bro this phone not connect to usb how to send screen shot
Sorry Give me more details
Old 01-13-2014, 08:36   #6 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,976
You did read with OLD version ?
You need read write with latest version
AzimBahar
The Following User Says Thank You to aZimBahar For This Useful Post:
Old 01-13-2014, 09:31   #7 (permalink)
Member: 1215266
Thanks Meter: 129
now this phone dead
bro not connect via usb
: Available Ports:COM5 COM61 COM62
>>Analysis of USB port,Please insert phone USB cable.
not read info
how connect via cable volcano???
Old 01-13-2014, 09:35   #8 (permalink)
Member: 1164608
Sonork: 100.1650273
Thanks Meter: 105
i have same cell phn duos s7562 mtk 6575 plug usb cable 1st + vol - key then butt batry phn will boot file size is about 1.75gb butt after flash with volcano set hang on logo. plz helpppppppppppppppp
Old 01-13-2014, 10:18   #9 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
you need working phone for backup
Old 01-13-2014, 10:28   #10 (permalink)
Member: 1215266
Thanks Meter: 129
this is backup phone new (
mt6575_kpd_gpio_set.bin)
Old 01-13-2014, 18:45   #11 (permalink)
Member: 1215266
Thanks Meter: 129
how connect mtk with volcano cable
Old 01-13-2014, 22:10   #12 (permalink)
AniAxn's Avatar
Member: 1045758
Thanks Meter: 4,307
Brother don't use Volcano main cable ...
Use only Nomal USB cable ...or modify cable if you have ..
Select Mtk android boot ...
Untik auto pinout ....
Tik usb mode...
Select flash file ...do run ...
When software search port..
Press boot key with battery & insert usb cale in off condition. ..
If you have modify cable no need press any boot key ...
Hope you do it....posr result....
Br,
AniAXN
Old 01-14-2014, 08:28   #13 (permalink)
Member: 1215266
Thanks Meter: 129
Tik usb mode...
Br,
AniAXN
I have this Cable
Old 01-14-2014, 11:18   #14 (permalink)
AniAxn's Avatar
Member: 1045758
Thanks Meter: 4,307
I have this Cable
Brother use normal micro usb cable(ca-101) ....
Br,
AniAXN
Old 01-14-2014, 12:37   #15 (permalink)
Member: 1215266
Thanks Meter: 129
Bro not coonect to USB phone dead
I know how to flashing via usb but this phone not connect with usb
Page generated in 0.33635 seconds with 8 queries
