11-12-2016, 15:21 | #1 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Bangladesh
Member: 2049143 Status: Offline Sonork: not use Thanks Meter: 270 | samsung clone format after dead [SOLVED] pettern lock problem try phone wipe data .hand and tools failed reed pettern failed auto format done but set dead please help team 18:05:17 Connecting... 18:05:17 CPU TYPE:MT6571 18:05:17 Hardware version:CA00 18:05:17 Software version:0000 18:05:18 SecCfgVal :0x00000000 18:05:18 BromVersion :0xFF 18:05:18 BLVersion :0x01 18:05:19 Boot downloading... 18:05:24 FlashID:00EC00BC00000055 18:05:24 Flash Type: NAND_K9K4G16Q0M 18:05:24 FlashLen:20000000 18:05:24 18:05:24 INT RAM: 5.31258MB SDRAM EXT RAM: 4.00391MB DRAM 18:05:24 MediaTek PreLoader USB VCOM Port (COM6) 18:05:24 Finding partition. 18:05:45 Flash reading... 18:07:34 Analysis UBI Failed, the program has terminated. 18:07:34 Read pattern lock failed. 18:07:57 18:07:57 Operation: 1. Power off the phone. 2. Please insert USB cable within 20 seconds. 18:07:57 18:08:07 Connecting... 18:08:08 CPU TYPE:MT6571 18:08:08 Hardware version:CA00 18:08:08 Software version:0000 18:08:08 SecCfgVal :0x00000000 18:08:08 BromVersion :0xFF 18:08:08 BLVersion :0x01 18:08:09 Boot downloading... 18:08:14 FlashID:00EC00BC00000055 18:08:14 Flash Type: NAND_K9K4G16Q0M 18:08:14 FlashLen:20000000 18:08:14 18:08:14 INT RAM: 5.31258MB SDRAM EXT RAM: 4.00391MB DRAM 18:08:14 MediaTek PreLoader USB VCOM Port (COM6) 18:08:14 Not support NAND phone, the program has terminated. 18:08:14 Wipe data/cache failed. 18:08:37 18:08:37 Operation: 1. Power off the phone. 2. Please insert USB cable within 20 seconds. 18:08:37 18:08:46 Connecting... 18:08:47 CPU TYPE:MT6571 18:08:47 Hardware version:CA00 18:08:47 Software version:0000 18:08:47 SecCfgVal :0x00000000 18:08:47 BromVersion :0xFF 18:08:47 BLVersion :0x01 18:08:48 Boot downloading... 18:08:53 FlashID:00EC00BC00000055 18:08:53 Flash Type: NAND_K9K4G16Q0M 18:08:53 FlashLen:20000000 18:08:53 18:08:53 INT RAM: 5.31258MB SDRAM EXT RAM: 4.00391MB DRAM 18:08:53 MediaTek PreLoader USB VCOM Port (COM6) 18:08:53 Finding partition. 18:09:22 Format range: Start Address: 0x14E4000000000000,Format Length :0xA780000 18:09:22 Flash erasing... 18:22:31 Available Ports:COM1 COM4 18:22:31 Current Port:Com0 now 19:51:01 Operation: 1. Power off the phone. 2. Please insert USB cable within 20 seconds. 19:51:01 19:51:06 Connecting... 19:51:06 CPU TYPE:MT6571 19:51:06 Hardware version:CA00 19:51:06 Software version:0000 19:51:06 SecCfgVal :0x00000000 19:51:06 BromVersion :0x05 19:51:06 BLVersion :0xFE 19:51:08 Boot downloading... 19:51:09 not find id. 19:51:09 Cannot connect with the phone, the program has terminated. 19:51:09 Read phone info Failed. |
The Following User Says Thank You to khorsed_pabna For This Useful Post: |
11-13-2016, 05:00 | #3 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | @khorsed_pabna Inferno Not Supported Some Of MTK NAND File System Read Pattern & Wipe User data Added Only for MTK EMMC , About Format up to your Log Its Shows Wrong Format Address . to Recover your Device Write your Backup Flash or Good Factory Flash File |
The Following 2 Users Say Thank You to zoneofash For This Useful Post: |
