03-22-2017, 06:52 | #6 (permalink) |
No Life Poster Join Date: Sep 2013 Location: India
Member: 2030192 Status: Offline Thanks Meter: 1,334 | I think U dont understand Check that mobile locked with Factory Reset Protection or not If not then flash custom recovery (tested) and boot into custom recovery there u can get adb and try to read/reset pattern If FRP enabled yes then no way to recover data now |
03-22-2017, 07:11 | #9 (permalink) |
Member: 2030192 Status: Offline Thanks Meter: 1,334 | Flash tested Custom recovery and use merapi for remove pattern lock check this update history for clarification http://forum.gsmhosting.com/vbb/11307827-post9.html |
03-22-2017, 07:43 | #13 (permalink) |
Member: 2030192 Status: Offline Thanks Meter: 1,334 | VolcanoBox 1.3.2 !! What's New ? Added OneClick Recovery for Samsung Phones 4.x to 5.x Tested Download Recovery Files from here Put Phone into Download mode & Connect with Computer Select Correct Model & Port & Select Recovery file & Start Wait Software Finish & Success Added OneClick Pattern Unlock Phone must be in Recovery you must write recovery 1st with Volcano then do this Connect phone with computer while phone is in custom recovery Select Recovery Mode Unock & Press Start if all ok your phones Pattern Lock/Pin code etc will be Removed without Data Lost Gmail bypass is not supported yet Added Tar ( img) file analysis put 8 GB memory card into phone phone must be with custom recovery select backup and restore from custom recovery make backup in Tar Format as backup done in memory card put card into pc and copy all files now select Tar(img) file analysis Select (backup) tar file and press start Gmail bypass is not supported yet it will read Pattern lock/pin code etc |
