03-11-2014, 07:58 | #1 (permalink) |
Freak Poster Join Date: May 2010
Member: 1315046 Status: Offline Thanks Meter: 36 | Sking I535i Pattern lock. Volcano Updated: 2014-03-05 2014-03-10 12:52:23 PM >>Connecting... 2014-03-10 12:52:28 PM >>Connection successful,connected state! 2014-03-10 12:52:28 PM >>Version: V3.8 2014-03-10 12:52:28 PM >>SN:416-275-713 2014-03-10 12:52:28 PM >>Port:COM4 2014-03-10 12:52:29 PM >>After format or Flash you have to press & hold power button for at least 1.30 mins. 2014-03-10 12:52:29 PM >>Note for win7 users : 2014-03-10 12:52:29 PM >>Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. 2014-03-10 12:52:29 PM >>After that the spd drivers will have the ability to be loaded. 2014-03-10 12:52:39 PM >>For many phones, charge pins need to be set in order to identify USB devices. 2014-03-10 12:52:39 PM >>Detecting D+ and D-... 2014-03-10 12:52:40 PM >>Vcc: null 2014-03-10 12:52:40 PM >>Gnd: 5 2014-03-10 12:52:40 PM >>Detection initiated... 2014-03-10 12:52:41 PM >>D+ = 3, D- = 2 2014-03-10 12:52:41 PM >>Detection D+/D- with 1.08 seconds. 2014-03-10 12:52:41 PM >>Continue to detect BOOT pin... 2014-03-10 12:52:45 PM >>Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) 2014-03-10 12:52:45 PM >>D+ = 3, D- = 2 2014-03-10 12:52:45 PM >>Detection completed. 2014-03-10 12:52:46 PM >>Setting pinouts... 2014-03-10 12:52:49 PM >>Find USB device:SCI USB2Serial (COM18), (VID_1782&PID_4D00) 2014-03-10 12:52:50 PM >>Pinout setting complete. 2014-03-10 12:52:58 PM >>Available Ports:COM1 COM4 COM18 2014-03-10 12:52:58 PM >> 2014-03-10 12:52:58 PM >> 2014-03-10 12:52:59 PM >>Internal version: SPRD3 2014-03-10 12:52:59 PM >>Boot downloading... 2014-03-10 12:52:59 PM >>Start boot please wait a moment.... 2014-03-10 12:53:01 PM >>Spreadtrum Boot Block version 1.1 2014-03-10 12:53:01 PM >>Boot downloading... 2014-03-10 12:53:02 PM >>CPU TYPE:SC8810/6820 [88100001] 2014-03-10 12:53:02 PM >>Flash ID: 00EC00BC00555400 2014-03-10 12:53:02 PM >>Flash Type:[SAMSUNG] K9F4G08/K9K4G08 2014-03-10 12:53:02 PM >>FLASH LEN:0x20000000 2014-03-10 12:53:02 PM >>Reading...(0) 2014-03-10 1:53:15 PM >>Read time: 60 min 12 s 2014-03-10 2:06:04 PM >>The data has been saved in C:\Documents and Settings\Mahesh\Desktop\_20140310_135502_FullFlash .bin, size: 512 M. handset is not in USB Debug mode, pls help me. |
03-11-2014, 08:10 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | if usb debugging not enabled then do with usb method Do Read Info First. If it gives message - "Analysis Flash internal data Successfully" then you can do format without any risk. If it gives message - "Analysis Flash internal data fail" then its risky to format the phone (Do format on your risk.) How to Format..See here - *Remove phone from USB Cable. *Format your device (Tick "Format" & press start) *Power OFF phone, insert battery and then insert usb cable. (If not detected, press volume up/volume down while inserting usb cable) *Handset will get formatted...check now Format only if you have working backup or firmware available at your collection. bR. Smk |
The Following User Says Thank You to Moiz Khan For This Useful Post: |
