04-18-2014, 20:47 | #1 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1953087 Status: Offline Thanks Meter: 10 | spd 6531 not flashing by volcano gets stuck on zero percent and machine gets hanged i font know where i m making mistake volcano team pls help me what to do to recover my phone from dead condition. thanks in advance |
04-18-2014, 21:06 | #2 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | @ metgsm .. Where is screen shot ..? Which version you use .? Allows post screen shot or phone status before do format .. For spd 6531 use Volcano 2.5.8 .. Also use baud rate 1843200 ... Try to flash with 2.5.8 & post result ... See the link - http://forum.gsmhosting.com/vbb/10218573-post1.html Br, AniAXN |
04-18-2014, 22:57 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | Same problem after format VolcanoTool_v2.6.0 Phone dead. I can not write flash read port Error Opening Greetings and thanks mfeliu07 Quote:
04-19-2014, 20:14 | #4 (permalink) | |
Member: 1953087 Status: Offline Thanks Meter: 10 | need expert help Quote:
04-19-2014, 22:46 | #5 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | @ metgsm ... If you don't post screen shot or about phone status ... I think no one can properly support you ... Team support must need details ... Or you Connect with me in yahoo I will see your matter ... Br, AniAXN |
04-20-2014, 18:37 | #6 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | where is screenshot is you are using latest version ? and stop on 0% is flash fie problem always for spd 6531 use latest version and read fllash file on buadrate 1843200 |
05-04-2014, 18:25 | #9 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | as already told you , you have bad flash file you must need to read flash file with latest version then write on faulty phone or try with other flash file |
05-06-2014, 09:05 | #10 (permalink) | |
Member: 1953087 Status: Offline Thanks Meter: 10 | Quote:
and request all volcano users pls give me its firware all details given in above screen shot. thank in advance | |
05-06-2014, 09:26 | #11 (permalink) | |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | Quote:
see the success report with old ver even can write flash maybe your file is not good read new file from working phone set baud rate 1843200 after write flash hold power bottom 30 to 50 second sometimes its take some time to boot up and use battery to boot up your phone not try with power supply lot of spd 6531a cpu not boot with power supply [IMG]****************************/convkey/5ba6/gxvwfupz5x8bubp6g.jpg[/IMG] hare is more of you http://forum.gsmhosting.com/vbb/f723...lcano-1808146/ br_mithun roy | |
04-08-2017, 14:50 | #14 (permalink) |
Junior Member Join Date: May 2016 Location: Pakistan punjab sargodha Age: 33
Member: 2574933 Status: Offline Thanks Meter: 5 | finly i tell you why not write flash file spd6531 from volcano. very simple you can only read flash file from volcano than you write on an other spd6531 same models it is 100% tested method so do not tried and waste the time for download from internet spd6531 model files and write from volcano. Last edited by needi malik; 04-08-2017 at 14:57. |
