01-16-2015, 13:53 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2010 Location: gsm hospital
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | spd 6531 without backup formated..dead..pls help i have gomax a180 CPU TYPE:SC6531 [65310001] FLASH ID: 00EF006000170000 Flash Type: SF_W25Q64DW Size:0x800000(8MB) formated without take backup phone dead..any working solutions?..pls help (i dont have backup flashfile ) |
01-16-2015, 14:33 | #2 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | For Spd6531 Use Always Volcano 2.7.2 version ..!! Do Follow this Step ..
You must need working firmware.. !! Wbr, AniAXN |
The Following 2 Users Say Thank You to AniAxn For This Useful Post: |
01-16-2015, 16:54 | #5 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | |
The Following User Says Thank You to AniAxn For This Useful Post: |
01-17-2015, 05:37 | #6 (permalink) | |
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | Quote:
i did all steps...still same.. any chance to get working file?... | |
01-17-2015, 05:40 | #7 (permalink) |
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | Volcano Updated: 2014-06-28 Connecting... Connection successful,connected state! Version: V3.8 SN:072-507-172 Port:COM15 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM1 COM2 COM15 Current Port:COM15 Available Ports:COM1 COM2 COM15 Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 1.08 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM63), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00EF006000170000 Flash Type: SF_W25Q64DW Size:0x800000(8MB) Reading completed. The data has been saved in C:\Documents and Settings\nasarpvr\Desktop\a 180\_20150117_095827_FullFlash.bin, size: 8 M. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 1.06 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM63), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Please change Boot or reduce Baudrate, try it again. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 1.08 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM63), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00EF006000170000 Flash Type: SF_W25Q64DW Size:0x800000(8MB) Set to Factory successfully. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 1.06 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM63), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00EF006000170000 Flash Type: SF_W25Q64DW Size:0x800000(8MB) Writing completed. Flash file C:\Documents and Settings\nasarpvr\Desktop\a 180\_20150117_095827_FullFlash.bin has been written. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 1.28 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM63), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00EF006000170000 Flash Type: SF_W25Q64DW Size:0x800000(8MB) >>Set to Factory successfully. |
01-21-2015, 06:45 | #11 (permalink) |
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | any body have working firmware for gomax a180? pls share Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310001] FLASH ID: 00EF006000170000 Flash Type: SF_W25Q64DW Size:0x800000(8MB) |
