Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 04-04-2012, 15:36   #1 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
spd 6600l booting problem but with dragon ok why?? [SOLVED]
2012-04-04 20:03:32 >>
2012-04-04 20:03:35 >>Internal version: Spreadtrum Boot Block version 2.0
2012-04-04 20:03:35 >>Boot downloading...
2012-04-04 20:03:36 >>CPU TYPE:SC6600L [66007001]
2012-04-04 20:03:36 >>FLASH ID:00EC225400000000
2012-04-04 20:03:36 >>Temporary does not support this flash.
2012-04-04 20:03:37 >>Please change Boot or reduce Baudrate, try it again.
The Following User Says Thank You to joni_rajpura For This Useful Post:
Old 04-04-2012, 20:32   #2 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
please kindly post the screenshot, i can't see clearly with ur log
what boot that already used and etc...?
regard,
Old 04-05-2012, 02:35   #3 (permalink)
Member: 338009
Thanks Meter: 3
set Baudrate 115200.try again.
Old 04-05-2012, 04:44   #4 (permalink)
Member: 312449
Thanks Meter: 9
this is the fact...in dragon no need to change baudrate or boot...
simply single klik works to detect and format ..
where as here too many process to perform same operation by volcano..
and B'cause of that i used to first try on dragon...if not work then VOLCANO
As i Know Work in Progress ....so no more comments...
MORE POWER TO VOLCANO
WBR...
Old 04-05-2012, 04:54   #5 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 440
yes yesterday i face same problem, easily detected on dragon but not on volcano.
Old 04-05-2012, 05:08   #6 (permalink)
Member: 508072
Thanks Meter: 1,621
i also try to reduce budrate but same and i select 6600l boot from list
Old 04-05-2012, 05:45   #7 (permalink)
Member: 508072
Thanks Meter: 1,621
Uploaded with ImageShack.us
Old 04-05-2012, 07:03   #8 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
can you please click on read flash instead of read info??
waiting for your result with screen shot.
br
Old 04-05-2012, 07:24   #9 (permalink)
Member: 1150309
Sonork: kumar
Thanks Meter: 5
same probhlum my.
012-04-05 11:24:32 AM >>Please change Boot or reduce Baudrate, try it again.
2012-04-05 11:32:41 AM >>Volcano Updated: 2012-04-01
2012-04-05 11:32:41 AM >>Connecting...
2012-04-05 11:32:43 AM >>Connection successful,connected state!
2012-04-05 11:32:43 AM >>Version: V3.8
2012-04-05 11:32:43 AM >>SN:014-805-762
2012-04-05 11:32:43 AM >>Port:COM8
2012-04-05 11:33:34 AM >>For many phones, charge pins need to be set in order to identify USB devices.
2012-04-05 11:33:35 AM >>Detecting D+ and D-...
2012-04-05 11:33:35 AM >>Vcc: 3
2012-04-05 11:33:35 AM >>Gnd: 11 12
2012-04-05 11:33:35 AM >>Detection initiated...
2012-04-05 11:33:36 AM >>D+ = 5, D- = 4
2012-04-05 11:33:36 AM >>Detection D+/D- with 1.16 seconds.
2012-04-05 11:33:36 AM >>Continue to detect BOOT pin...
2012-04-05 11:33:40 AM >>Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
2012-04-05 11:33:40 AM >>BOOT(Pull Down) = 7
2012-04-05 11:33:40 AM >>Detection completed.
2012-04-05 11:33:47 AM >>Setting pinouts...
2012-04-05 11:33:59 AM >>Pinout setting complete.
2012-04-05 11:34:21 AM >>Available Ports:COM1 COM8 COM9
2012-04-05 11:34:21 AM >>Detection initiated...
2012-04-05 11:34:21 AM >>Vcc: 3
2012-04-05 11:34:21 AM >>Gnd: 11 12
2012-04-05 11:34:21 AM >>Analyzing D+ and D-...
2012-04-05 11:34:23 AM >>D+ = 5, D- = 4
2012-04-05 11:34:23 AM >>Detection D+/D- with 1.16 seconds.
2012-04-05 11:34:23 AM >>Continue to detect BOOT pin...
2012-04-05 11:34:28 AM >>Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
2012-04-05 11:34:28 AM >>BOOT(Pull Down) = 7
2012-04-05 11:34:28 AM >>Setting...
2012-04-05 11:34:31 AM >>Find USB device:SCI USB2Serial (COM9), (VID_1782&PID_4D00)
2012-04-05 11:34:31 AM >>Pinouts setting complete!
2012-04-05 11:34:32 AM >>
2012-04-05 11:34:34 AM >>Internal version: Spreadtrum Boot Block version 2.0
2012-04-05 11:34:34 AM >>Boot downloading...
2012-04-05 11:34:35 AM >>CPU TYPE:SC6600L [66007001]
2012-04-05 11:34:35 AM >>FLASH ID:0001227E22102201
2012-04-05 11:34:35 AM >>Flash Type:[SPANSION] S71PL064
2012-04-05 11:34:35 AM >>Size:0x800000(8MB)
2012-04-05 11:34:36 AM >>Please change Boot or reduce Baudrate, try it again.
2012-04-05 11:34:45 AM >>Detection initiated...
2012-04-05 11:34:46 AM >>Vcc: 3
2012-04-05 11:34:46 AM >>Gnd: 11 12
2012-04-05 11:34:46 AM >>Analyzing D+ and D-...
2012-04-05 11:34:56 AM >>D+ = 5, D- = 4
2012-04-05 11:34:56 AM >>Detection D+/D- with 3.84 seconds!
2012-04-05 11:34:56 AM >>Analyzing USB device, please wait...
2012-04-05 11:35:10 AM >>Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
2012-04-05 11:35:10 AM >>Setting...
2012-04-05 11:35:14 AM >>Find USB device:SCI USB2Serial (COM9), (VID_1782&PID_4D00)
2012-04-05 11:35:14 AM >>Pinouts setting complete!
2012-04-05 11:35:16 AM >>Internal version: Spreadtrum Boot Block version 2.0
2012-04-05 11:35:16 AM >>Boot downloading...
2012-04-05 11:35:18 AM >>CPU TYPE:SC6600L [66007001]
2012-04-05 11:35:18 AM >>FLASH ID:0001227E22102201
2012-04-05 11:35:18 AM >>Flash Type:[SPANSION] S71PL064
2012-04-05 11:35:18 AM >>Size:0x800000(8MB)
2012-04-05 11:35:18 AM >>Please change Boot or reduce Baudrate, try it again.
2012-04-05 11:35:49 AM >>Detection initiated...
2012-04-05 11:35:50 AM >>Vcc: 3
2012-04-05 11:35:50 AM >>Gnd: 11 12
2012-04-05 11:35:50 AM >>Analyzing D+ and D-...
2012-04-05 11:35:51 AM >>D+ = 5, D- = 4
2012-04-05 11:35:51 AM >>Detection D+/D- with 1.16 seconds.
2012-04-05 11:35:51 AM >>Continue to detect BOOT pin...
2012-04-05 11:35:56 AM >>Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
2012-04-05 11:35:56 AM >>BOOT(Pull Down) = 7
2012-04-05 11:35:56 AM >>Setting...
2012-04-05 11:36:00 AM >>Find USB device:SCI USB2Serial (COM9), (VID_1782&PID_4D00)
2012-04-05 11:36:00 AM >>Pinouts setting complete!
2012-04-05 11:36:00 AM >>Temporary does not support this guide to read the information function
2012-04-05 11:36:09 AM >>Detection initiated...
2012-04-05 11:36:10 AM >>Vcc: 3
2012-04-05 11:36:10 AM >>Gnd: 11 12
2012-04-05 11:36:10 AM >>Analyzing D+ and D-...
2012-04-05 11:36:11 AM >>D+ = 5, D- = 4
2012-04-05 11:36:11 AM >>Detection D+/D- with 1.16 seconds.
2012-04-05 11:36:11 AM >>Continue to detect BOOT pin...
2012-04-05 11:36:16 AM >>Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
2012-04-05 11:36:16 AM >>BOOT(Pull Down) = 7
2012-04-05 11:36:16 AM >>Setting...
2012-04-05 11:36:20 AM >>Find USB device:SCI USB2Serial (COM9), (VID_1782&PID_4D00)
2012-04-05 11:36:20 AM >>Pinouts setting complete!
2012-04-05 11:36:20 AM >>Temporary does not support this guide to read the information function
2012-04-05 11:36:22 AM >>Detection initiated...
2012-04-05 11:36:23 AM >>Vcc: 3
2012-04-05 11:36:23 AM >>Gnd: 11 12
2012-04-05 11:36:23 AM >>Analyzing D+ and D-...
2012-04-05 11:36:24 AM >>User stop
2012-04-05 11:36:24 AM >>Pinouts are not fonud!
2012-04-05 11:36:30 AM >>
2012-04-05 11:36:45 AM >>Please change Boot or reduce Baudrate, try it again.
2012-04-05 11:36:54 AM >>Clearing pinouts...
2012-04-05 11:36:55 AM >>Clearing pinouts complete!
2012-04-05 11:37:06 AM >>Detecting rx and tx...
2012-04-05 11:37:07 AM >>Vcc: 3
2012-04-05 11:37:07 AM >>Gnd: 11 12
2012-04-05 11:37:07 AM >>Detection initiated, connect the phone and power on it...
2012-04-05 11:38:21 AM >>User stop
dragonlog
Initializing...
DA_LIB_VER_4.0.3.2
It is sensing the pinout fast...
D-=4 D+=5
Searching commport...please wait...
Connecting...
Spd USB-to-Serial=COM7
Connected...sending boot...
FDL test...OK
ArmBootMode: 6600700100005A00_00
Wait for init Commzero Security Engine...
Done.
Loading bootloader...
Done.
Changing baudrate...
Set baudrate to 115200 is ok
Reading phone HW info...
Read info is done.
CPU: SC6600L2 Flash: NOR_S29GL064A_T
setting the Flash Parameters...
Settings have been completed!
Reading FileSystem info...
File System Ver: 0A
IMEI 1=354762048362005
IMEI 2=354762048362013
Failed to get address of NV.
Read FS info...done
Old 04-05-2012, 08:38   #10 (permalink)
Member: 508072
Thanks Meter: 1,621
br
can we make contect vaya team viewer
Old 04-05-2012, 09:04   #11 (permalink)
Member: 508072
Thanks Meter: 1,621
yes working good when reading flesh file see but what about info ????????
and after reding file didnt ask me to save file ?????
Old 04-05-2012, 09:24   #12 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
read info have bugs, but no matter, you can read flash, write flash, format without single problem.
now go to C/ programe files/ volcano team/ , and check there will be a file named temp_06 or temp_08,
just rename that file with your phone model.
that is your readed file, you can use it.
br
The Following User Says Thank You to .::M Irfan::. For This Useful Post:
Old 04-05-2012, 10:34   #13 (permalink)
Member: 508072
Thanks Meter: 1,621
hope that bugs fixed soon by volcano team
Old 04-05-2012, 15:12   #14 (permalink)
Member: 759840
Thanks Meter: 6
same here
is problem ka koi solution hai
Old 04-05-2012, 18:51   #15 (permalink)
.::jagdeep-Gupta::.'s Avatar
Member: 787829
Sonork: 100.1615114
Thanks Meter: 917
Arrow
ALREADY GIVEN ANSWER MY BRO THEN WHY ASKING SAME QUESTION
wbr
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:48
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.24150 seconds with 10 queries
