SPD 8810/6820 dead after read info Volcano version 2.1.9 China android A7100 SPD 8810/6820 dead after read info Volcano version 2.1.9 In New version 2.2.1 i read info from this phone: Detection initiated... Vcc: null Gnd: 7 Analyzing D+ and D-... D+ = 4, D- = 3 Detection D+/D- with 6,82 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 5 Setting... Find USB device:SPRD U2S Diag (COM87), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 009800BC90667600 Flash Type:[TOSHIBA] TYBC0A111236KC10 FLASH LEN:0x20000000 File partition was not found. http://img33.imageshack.us/img33/7735/938j.jpg Dear team, what's problem? hardware or software? |
Detection initiated... Vcc: null Gnd: 7 Analyzing D+ and D-... D+ = 4, D- = 3 Detection D+/D- with 6,18 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 5 Setting... Find USB device:SPRD U2S Diag (COM87), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 009800BC90667600 Flash Type:[TOSHIBA] TYBC0A111236KC10 FLASH LEN:0x20000000 Reading completed. Read time: 35 min 57 s The data has been saved in D:\MTK\SPD\Jek_a7100_20130801_113437_FullFlash.bin , size: 512 M. but i can't write, this is log: Detection initiated... Vcc: null Gnd: 7 Analyzing D+ and D-... D+ = 4, D- = 3 Detection D+/D- with 6,19 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 5 Setting... Find USB device:SPRD U2S Diag (COM87), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. I can't format and write to this phone via volcano! Pls, how to solve my problem! Thanks! |
This is screenshot write not possible http://img202.imageshack.us/img202/9108/6g1c.jpg format not possible http://img844.imageshack.us/img844/342/zev6.jpg |
spd 6820/8810 read flash super slow............. version V2.2.1 |
hello try to push both volume + and volume - buttons when detecting pinouts about 10-15 seconds |
@dracony Select Baud Rate 921600 First Do Read info then Do Write Flash. BR Qaisar Mahmood |
Read info log Detection initiated... Vcc: null Gnd: 7 Analyzing D+ and D-... D+ = 4, D- = 3 Detection D+/D- with 6,83 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 5 Setting... Find USB device:SPRD U2S Diag (COM87), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 009800BC90667600 Flash Type:[TOSHIBA] TYBC0A111236KC10 FLASH LEN:0x20000000 File partition was not found. after this do write http://img202.imageshack.us/img202/9092/twx1.jpg |
First read Info then try write flash file and post result |
read info log: Detection initiated... Vcc: null Gnd: 7 Analyzing D+ and D-... D+ = 4, D- = 3 Detection D+/D- with 6,72 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 5 Setting... Find USB device:SPRD U2S Diag (COM87), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 009800BC90667600 Flash Type:[TOSHIBA] TYBC0A111236KC10 FLASH LEN:0x20000000 File partition was not found. write info log: Detection initiated... Vcc: null Gnd: 7 Analyzing D+ and D-... D+ = 4, D- = 3 Detection D+/D- with 6,33 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 5 Setting... Find USB device:SPRD U2S Diag (COM87), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. |
try on 2.2.1.1 and post result if still same then this flash ic is not supported yet |
Full flash write done but phone still dead! help! thanks! Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 1,51 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) UsbVcc(VCC) = 1 10, BOOT(Pull Down) = 4 Setting... Find USB device:SCI USB2Serial (COM237), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 009800BC90667600 Flash Type:[TOSHIBA] TYBC0A111236KC10 Flash writing userdata...100% Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. |
i have a phone with the same name . and dead after format with old volcano version . any one pls help me this file . ------------------------------------------------ CPU TYPE:SC8810/6820 [88100001] Flash ID: 009800BC90667600 Flash Type:[TOSHIBA] TYBC0A111236KC10 FLASH LEN:0x20000000 |
