02-05-2014, 07:59 | #1 (permalink) |
Freak Poster Join Date: Aug 2011 Location: Uganda Age: 42
Member: 1640892 Status: Offline Sonork: 100.1651734 Thanks Meter: 25 | SPD Android reset gmail without usb debugging when locked to gmail without usb debugging with volcano br baruga |
02-05-2014, 11:37 | #3 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Flow rizwankhan8670 Also you can do With User Data file If you have same working phone Do backup with volcano Then Create PAC File & flash Br AzimBahar |
The Following User Says Thank You to aZimBahar For This Useful Post: |
02-05-2014, 15:50 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | @ baruga bro first do read info if analyzing successfully then do format if fail then not do format BR Qaisar Mahmood |
The Following User Says Thank You to Qaisar Mahmood For This Useful Post: |
02-05-2014, 20:02 | #6 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | brother try to go in fast boot mode , before doing risky format try different key combination and try to take it on fast boot mode and after fast boot mode try wipe it if not go in fast boot mode then you have only solution is format and do format at your own risk |
