Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Volcano Box
Old 05-10-2013, 18:30   #1 (permalink)
power_zone's Avatar
Member: 1449003
Sonork: tariq (100.1603714)
Thanks Meter: 38
Arrow spd N9300 samsung android no format pattern lock problem.
Vcc: null
Gnd: 5
Analyzing D+ and D-...
D+ = 3, D- = 2
Analyzing USB device, please wait...
Find USB device:SCI USB2Serial (COM44), (VID_1782&PID_4D00)
Internal version: SPRD3
Boot downloaded.
>>Start boot please wait a moment....
here is shot but not working please help.....with me dear....i already try with
Old 05-10-2013, 21:17   #2 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,361
select boot 6820/8810
only format and imei supported yet
and do format your own risk bec
read and write flash not supported yet
Old 05-11-2013, 06:25   #3 (permalink)
amit_gsm's Avatar
Member: 665514
Sonork: 100.1618806
Thanks Meter: 323
Dear Volcano Team Need To Add This Option
Old 05-29-2013, 17:06   #4 (permalink)
power_zone's Avatar
Member: 1449003
Thanks Meter: 38
Arrow Thanks Volcano n9300 6820/8810pattern lock remove succes
Volcano Updated: 2013-05-17
Connecting...
Connection successful,connected state!
Version: V3.8
SN:147-548-004
Port:COM11
After format or Flash you have to press & hold power button for at least 1.30 mins.
Note for win7 users :
Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'.
After that the spd drivers will have the ability to be loaded.
Connecting...
Version: V3.8
SN:147-548-004
Port:COM11
Available Ports:COM1 COM11
Detection initiated...
Vcc: null
Gnd: 5
D+ = 3, D- = 2
Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
Setting...
Set the Pinouts failed,please reconnect and try again!
Vcc: null
Gnd: 5
D+ = 3, D- = 2
Find USB device:SCI USB2Serial (COM21), (VID_1782&PID_4D00)
Temporary does not support this guide to read the information function
Vcc: null
Gnd: 5
D+ = 3, D- = 2
Boot downloaded.
Spreadtrum Boot Block version 1.1
Boot downloaded.
Flash ID: 00AD00BC
Flash Type:[Hyundai] NAND_HY27UT088G2A
FLASH LEN:0x20000000
Set to Factory successfully.
samsung china n9300 6820/8810pattern lock remove succes by POWER ZONE...
Old 05-29-2013, 20:07   #5 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,361
We are happy to see problem solved and enjoy the power of volcano
Old 10-24-2013, 12:33   #6 (permalink)
Member: 1607666
Sonork: oke
Thanks Meter: 4
Connecting...
Version: V3.8
SN:147-548-004
Port:COM11
Connecting...
Version: V3.8
SN:147-548-004
Port:COM11
Vcc: null
Gnd: 5
D+ = 3, D- = 2
Setting...
Vcc: null
Gnd: 5
D+ = 3, D- = 2
Vcc: null
Gnd: 5
D+ = 3, D- = 2
Boot downloaded.
Boot downloaded.
Flash ID: 00AD00BC
same problem im not luck....please ficture n tutorial master
Old 10-24-2013, 12:41   #7 (permalink)
ch mobiles's Avatar
Member: 748029
Sonork: 100.1603742
Thanks Meter: 1,820
Hi,
Post Logs Or Screenshot for help Then We Will Help You.
B,R.
Page generated in 0.36418 seconds with 7 queries
