05-10-2014, 14:54 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: bangladesh, chittagong
Member: 648453 Status: Offline Thanks Meter: 82 | spraderm android problems [Solved] then i go to spd and select boot also try boot 14no. read info not done try insert battery or without battery no phone info show or detact pinout fail. also try android tab select spd usb but no response. i have two set one is gmail id other hang on logo please help. i use normal nokia usb cable |
05-10-2014, 16:07 | #2 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | @ sahed07860 .... Do As I say ... If you use Normal USB Cable .. Insert Buttery in Phone .. Press boot Key (vol+/vol-) .. Then Plug USB Cable .. You Can Try Also Modify Cable - http://forum.gsmhosting.com/vbb/9347474-post1.html Also You Try Volcano Main Cable ... As Like Below -
Br, AniAXN |
05-10-2014, 18:46 | #3 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | untick mark auto detect pinouts select your spd port select boot 14 select job press run button and post result |
05-11-2014, 06:20 | #4 (permalink) | |
Member: 648453 Status: Offline Thanks Meter: 82 | Quote:
