05-10-2015, 07:44 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: India
Member: 2030192 Status: Offline Thanks Meter: 1,334 | Strange problem Micromax a34 blue display only after BOLT logo need solution>>>>> already flashed with factory .pac file but same problem tried auto format with volcano but same problem on back sticker h/w ver: v1.0.0 s/w ver: v1.0.9 tried with factory pac file's v1.0.9 and v1.1.1 with all available h/w info volcano read info:- Code: Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100040] Flash ID: 002C00BC90665400 Flash Type:[Micron] MT29C4G48MAZAPAKD FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjaluna),1536k(fastboot_logo),2560k(productinfo),3328k(fixnv),3328k(backupfixnv),3m(boot_logo),3328k(runtimenv),8m(boot),8m(recovery),200m(system),202m(userdata),60m(cache),256k(misc),10m(modem),5m(dsp),512k(kpanic) >>Analysis flash internal data successfully. |
05-10-2015, 08:11 | #2 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Brother @blacky199 I Think Your Tryed All of S/W Solutions For It ... Not Done Then try to Change a LCD and Check Out and If You're Flashed Phone With Official Stock Rom or What ? And Try as You Know Same Working Good Mobile Read File and Write Your Faulty Device and Check Out |
05-10-2015, 08:22 | #4 (permalink) |
Member: 2030192 Status: Offline Thanks Meter: 1,334 | @zoneofash sorry for now i don't have working mobile in hand to read and write it on so i already open file request in flash file section hope some one will respond it @amn32 i can't any other factory firmware except v1.0.9 & v1.1.1 and this mobile have multiple h/w info and i checked with all h/w info and both version |
05-10-2015, 08:27 | #5 (permalink) |
No Life Poster Join Date: Jul 2014 Location: Online Age: 28
Member: 2218251 Status: Offline Thanks Meter: 1,096 | same problerm in MICROMAX A40..I FLASH WITH ALL VERSION AND ALSO CHANGE LCD BUT STILL MY PROBLEM NOT SOLVE http://forum.gsmhosting.com/vbb/f811...-blue-1928227/ |
05-18-2015, 09:38 | #6 (permalink) |
Member: 2030192 Status: Offline Thanks Meter: 1,334 | problem solved hardware issue solution : change lcd or check short on resister in lcd in my case short on c11 resister |
The Following User Says Thank You to blacky199 For This Useful Post: |
