Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 05-21-2017, 11:36   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Telefunken tel-73giqsSPD
I try to connect this tablet with all software but all failed ..
I took info with miracle box with ADB . I got two tablet one is working and one is need to format.
This info is from working tablet.
>>Current Task: Read Information>>SC7730/31 EMMC
>>Operation:
1.Remove battery and insert battery back.
2.Press and hold 'VolumeUp' and 'VolumeDown' keys.
3.Please insert USB cable within 60 seconds.
>>Analysis of USB port,Please insert phone USB cable.
>>Internal version: SPRD3
>>Boot downloaded.
>>Boot start failed.Boot does not match.
Definition Applied
Connecting to Phone,Wait..ok
Hardware:sc7731
Board:k03_swk_7inch_64_8
CPU ABI:armeabi-v7a
Manufacturer:zooch
Model:tel-73giqs
Android Ver:5.1
bootloader ver:unknown
USB config:mtp,adb
User:caichengxiang
Baseband ver:tm_base_mp_ii_w15.31|sc7731g_cp0_modem|07-28-2015 11:08:42
Build number:lmy47d release-keys
Region:za
Language:en
Chipset:sc8830
Root: Not Root
>>Done
Old 05-21-2017, 11:43   #2 (permalink)
ij_cell's Avatar
Member: 1937038
Sonork: QQ 2045657399
Thanks Meter: 4,492
Hi
Use boot Android 5.x.x with tick on Higher Boot version loader and do format it,If still boot not matched than use only Higher Boot Version and check.Post result
BR.
Sehar
GPG Team
The Following User Says Thank You to ij_cell For This Useful Post:
Old 05-21-2017, 11:54   #3 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Originally Posted by ij_cell View Post
Hi
BR.
Sehar
GPG Team
Old 05-21-2017, 11:59   #4 (permalink)
ij_cell's Avatar
Member: 1937038
Thanks Meter: 4,492
Seems another 2nd HW revision of this tab.Need to figure out about it.Anyway it was flashed well boot is supported long time ago of this device it might be HW issue check link below
http://forum.gsmhosting.com/vbb/f723...ll-ok-2172249/
BR.
Sehar
GPG Team
Old 05-21-2017, 12:29   #5 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
BR.
Sehar
GPG Team
this link is from JANUARY.. since from that time i m busy on this tablet.. but no luck..
Thanks for your reply.
But i am totaly disagree with you sir.
Because i got more than 5 tablets some are blinking some stuck.
But this one i got its working 100% no problem
I just want to make sure why ..
Is it possible that my drivers are not correct.
But i am also doing other sc7731 very nicley....
Old 05-21-2017, 12:44   #6 (permalink)
ij_cell's Avatar
Member: 1937038
Thanks Meter: 4,492
Agreed
It might be another HW revision as i said.Personally i face kind of devices.Not yet supported till got its .pac file.Anyway its not drivers issue.
Sorry for any inconvenience
BR.
Sehar
GPG Team
Page generated in 0.15955 seconds with 10 queries
