Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 04-20-2014, 12:50   #1 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
Arrow [Tutorial]For MTK 6260 or 625A USB Method ...
..:: How To Connect MTK 6260 or 625A in USB Mode By Volcano ::..
First Open Latest Volcano Software
Using Volcano Main Cable
Install Mtk Driver Properly - MTK & CDC Driver - Download - 4shared
Go To Detect Tab & Set pin First
After Set Pinout Hear You See in Device Manager which Port is Connect
After That Port is Lost from Device Manager & Phone Shown to Charging Mode
Then Remove the Volcano Main Jig Cable Only
But Power Cable Sill Connect With Phone ...Just Like That ...
Now Go To Mtk Tab & Select Boot 11
Untick Auto Detect pin-out & Tick Usb Mode
Select Read,Write or Other
After That When Software Say Analysis Usb Port ..
Then Connect Volcano Jig cable to Phone Like That ..
After Connect Cable Work Is Start Easily
In That Way You Can Do Read,Write or Format
Note - This Method also work with MT6261 Chip ..
Best Regard
AniAXN
The Following 7 Users Say Thank You to AniAxn For This Useful Post:
Old 04-20-2014, 13:16   #2 (permalink)
AniAxn's Avatar
Member: 1045758
Thanks Meter: 4,307
Arrow [Tutorial]For MTK 625A Rebuild IMEI So easy ...
Follow This Step ...
  • First Go to Detect tab ..
  • Select to Pinfind "MTK USB & Mstar (Do Find Boot)" type ..
  • After pin find click to Set Pin-out ...
  • Now Remove Jig cable & Power cable from phone ...
  • Power on the phone with buttery ...
  • Now connect only Jig cable ...
  • A Screen will come on the phone ...
  • Now you select to com port in the phone ...
  • See the Device Manager which number port is connect ...
  • Now Run Volcano ....See bellow ...
  • Set manually com in IMEI tool box ...
  • Fill the IMEI number
  • & click Write IMEI ...
Br,
AniAXN
The Following 4 Users Say Thank You to AniAxn For This Useful Post:
Old 11-23-2014, 03:05   #3 (permalink)
Member: 2249798
Thanks Meter: 26
Sir after select type when i click on Detect it show failed to detect after 4 ,,..5 second....
Old 11-27-2014, 07:50   #4 (permalink)
AniAxn's Avatar
Member: 1045758
Thanks Meter: 4,307
Post error Screen Shot First ..
Wbr,
AniAXN
Old 02-09-2015, 09:30   #5 (permalink)
Member: 584188
Thanks Meter: 4
Connecting...
Hardware version:CB01
Software version:0001
CPU TYPE:6261
>>Internal version:8000
VolcanoUtility_v2.9.1 old box not support help...........
Old 02-09-2015, 14:22   #6 (permalink)
AniAxn's Avatar
Member: 1045758
Thanks Meter: 4,307
Originally Posted by nasirulhuda View Post
Connecting...
CPU TYPE:6261
Hello ..
Download Volcano Latest Version 2.9.2 First ..!!
Do detect as like 1st post ..
If any problem connect me in yahoo or skype ..!!
Wbr,
AniAXN
Old 02-09-2015, 14:42   #7 (permalink)
Member: 2096569
Thanks Meter: 4
Good share. keep it up Vree Nice
Old 02-09-2015, 15:54   #8 (permalink)
Registered User
Member: 1784151
Sonork: 0
Thanks Meter: 75
At first post why we need usb cable if we can use main cable to read and flash? i think just find correct boot key if use usb cable
Old 05-27-2015, 18:17   #9 (permalink)
Member: 427344
Sonork: 100.1666688
Thanks Meter: 213
if u know boot button then its really very easy to work .why does our p.m make a different section for boot keys only so that it would only take half a minute to format mtk 6250 mtj 6260
Old 05-27-2015, 18:21   #10 (permalink)
zoneofash's Avatar
Member: 1445819
Thanks Meter: 4,976
Smile
All Users Know .. 90% MTK 62** Phones No Need Press Any Boot Key .. Just Put USB Cable Only .. But Some Phones Need to Press it ... Most Phones Boot Keys is Volume Down Key Others Power Key ..
Old 08-16-2015, 07:30   #11 (permalink)
Member: 1809212
Sonork: 1000.2
Thanks Meter: 79
how to work if Kcolo is present
please explain
Old 08-16-2015, 08:30   #12 (permalink)
Member: 1164608
Sonork: 100.1650273
Thanks Meter: 105
thanx alot for mentioning 1 by 1 step this guidenes is enough for these type of models....
Old 08-21-2015, 19:33   #13 (permalink)
Member: 1948740
Sonork: 100.1645832
Thanks Meter: 13
good job .....carry on bro........
Old 10-05-2015, 20:42   #14 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
could you more explain me why should i select boot 11 instead of auto boot ?
Old 10-06-2015, 14:32   #15 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
Hey I'm Nicely succeed by this easy tutorial , thanks for this useful tips
Page generated in 0.20118 seconds with 8 queries
