04-20-2014, 12:50 | #1 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | [Tutorial]For MTK 6260 or 625A USB Method ... ..:: How To Connect MTK 6260 or 625A in USB Mode By Volcano ::.. First Open Latest Volcano Software Using Volcano Main Cable Install Mtk Driver Properly - MTK & CDC Driver - Download - 4shared Go To Detect Tab & Set pin First After Set Pinout Hear You See in Device Manager which Port is Connect After That Port is Lost from Device Manager & Phone Shown to Charging Mode Then Remove the Volcano Main Jig Cable Only But Power Cable Sill Connect With Phone ...Just Like That ... Now Go To Mtk Tab & Select Boot 11 Untick Auto Detect pin-out & Tick Usb Mode Select Read,Write or Other After That When Software Say Analysis Usb Port .. Then Connect Volcano Jig cable to Phone Like That .. After Connect Cable Work Is Start Easily In That Way You Can Do Read,Write or Format Note - This Method also work with MT6261 Chip .. Best Regard AniAXN Last edited by AniAxn; 01-28-2015 at 06:46. Reason: Add some Info .. |
The Following 7 Users Say Thank You to AniAxn For This Useful Post: |
04-20-2014, 13:16 | #2 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | [Tutorial]For MTK 625A Rebuild IMEI So easy ... For MTK 625A Rebuild IMEI So easy ... Follow This Step ...
Br, AniAXN Last edited by AniAxn; 04-20-2014 at 13:22. |
The Following 4 Users Say Thank You to AniAxn For This Useful Post: |
02-09-2015, 14:22 | #6 (permalink) | |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Quote:
Hello .. Download Volcano Latest Version 2.9.2 First ..!! Do detect as like 1st post .. If any problem connect me in yahoo or skype ..!! Wbr, AniAXN | |
05-27-2015, 18:17 | #9 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 427344 Status: Offline Sonork: 100.1666688 Thanks Meter: 213 | if u know boot button then its really very easy to work .why does our p.m make a different section for boot keys only so that it would only take half a minute to format mtk 6250 mtj 6260 |
05-27-2015, 18:21 | #10 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | All Users Know .. 90% MTK 62** Phones No Need Press Any Boot Key .. Just Put USB Cable Only .. But Some Phones Need to Press it ... Most Phones Boot Keys is Volume Down Key Others Power Key .. |
08-16-2015, 08:30 | #12 (permalink) |
No Life Poster Join Date: Nov 2009 Location: pakistan Age: 35
Member: 1164608 Status: Offline Sonork: 100.1650273 Thanks Meter: 105 | thanx alot for mentioning 1 by 1 step this guidenes is enough for these type of models.... Last edited by AniAxn; 08-18-2015 at 21:31. Reason: Question remove!! |
