12-19-2014, 10:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: India
Member: 1860537 Status: Offline Sonork: 1657411 Thanks Meter: 39 | urjent help volcano team so plz help [IMG][/IMG] Volcano Updated: 2014-10-22 Connecting... Connection successful,connected state! Version: V3.8 SN:656-907-692 Port:COM149 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM3 COM12 COM33 COM58 COM149 Detection initiated... Vcc: null Gnd: 1 Analyzing D+ and D-... D+ = 3, D- = 4 Analyzing USB device, please wait... Find USB device:SCI USB2Serial (COM62), (VID_1782&PID_4D00) failed to open port. >>Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. rda8851 [IMG][/IMG] |
12-19-2014, 11:34 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | For SPD You need to press some boot key For Coolsand looks like you are doing in usb mode. If yes, then you need to keep pressing "0" button while detection of usb. Handset will show charging..and then usb will gets detected after 5 seconds. Be sure that proper coolsand usb drivers are installed. bR. Smk |
The Following User Says Thank You to Moiz Khan For This Useful Post: |
12-19-2014, 13:59 | #4 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Connect coolsand mobile chip with volcano main cable or use rx tx cable , for spd it's possibly driver problem you can also try comport option , change type option from usb to com (rx/tx) . |
