Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 03-21-2014, 17:13   #1 (permalink)
Member: 1833113
Sonork: 100.1623537
Thanks Meter: 40
Karbonn A36 SPD 6285 pattern locked removed sucessfully
Karbonn a36 spd 6285 pattern lock removed by volcano 2.5.5(used) just see the picture hope u guys know procedure.
Old 05-12-2014, 22:37   #2 (permalink)
Member: 508303
Thanks Meter: 8
KARBONN A 36 HARD RESET WITHOUT ANY TOOL
install all the Spd android drivers first.
open android multi tools ver 1.02b
in that u will see 3 folders and other set up files.
open recovery and download folder
in that open recovery folder
click recovery icon.
now the mobile will enter recovery mode automatically.
remove the usb cable if u wish
now press (volume +) i,e (volume up) key to see the menu options
select wipe data or factory reset
finally press power key. thats it
I HOPE U UNDERSTAND MY ENGLISH
enjoy.
Old 05-13-2014, 04:35   #3 (permalink)
guddu ahmad's Avatar
Member: 1345926
Sonork: 100.1671229
Thanks Meter: 176
no UNDERSTAND
open multi tool 1.02b then 3 folder .where come 3 folder?
plz .give solution step by step.
Old 05-19-2014, 10:36   #4 (permalink)
sangaistalin's Avatar
Member: 1474141
Sonork: 100.1647675
Thanks Meter: 66
uni- antroid v4.0 used to remove pattern lock karbon a36 100% tested
Old 06-28-2014, 06:50   #5 (permalink)
Member: 1266304
karbonn a36 pattern unlock
thanks sir ur right
Old 07-04-2014, 07:38   #6 (permalink)
Member: 698658
i can`t connect plz tell me how to connect unable to connect the device make sure data cable is connected to the device plz help me my mobile number 08608499533 give miss call i will call u
Old 07-04-2014, 08:24   #7 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
if usb dubbing enable then you can do your job
other wise do format or check sticky post
Old 10-18-2014, 11:36   #8 (permalink)
Member: 1146818
Thanks Meter: 4
Wink karboon a36 hard reset without usb debgging
just open volcano utility 2.8.1 go in abd tab select shift in recovery mode n do hard reset dats it........enjoy
Old 02-01-2015, 10:38   #9 (permalink)
Member: 1116231
Sonork: 1636983
Thanks Meter: 17
karbon a36 hardreset
karbon a36 hardreset done in volcano follow step by step
1.open volcano
2.select android
3.select adb mode
4.just select shift mode
5.after select shift just select reocvey
your device going to recover and just reset your device thanks to volcano
Old 02-25-2015, 13:41   #10 (permalink)
Member: 2352810
i need android multi tool
Page generated in 0.22124 seconds with 10 queries
