05-06-2014, 15:44 | #37 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan Age: 35
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | I think if every thing is ok in system self check menu then there is noob problem i am also noob and trying to detect different connected phones from past three days but unfortunately no luck. I am still reading user manual and i think detecting the phone with volcano box is the most complicated thing , please make its interface easy in next update ? and for now please give me some suggestions how to detect any connected devices ?. logs always appear like this when ever i tried to detect any phone.. the logs below appear while detecting Qmobile A600 USB devices. Detecting D+ and D-... Vcc: null Gnd: null Detection initiated... User stop For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: null Detection initiated... Failed to detect. Available Ports:COM25 Detection initiated, connect the phone and power on it... Vcc: null Gnd: null Analyzing Rx and Tx... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... Failed to detect. Pinouts are not fonud! Detection initiated, connect the phone and power on it... Vcc: null Gnd: null Analyzing Rx and Tx... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... Failed to detect. >>Pinouts are not fonud! Thanks in advance. Last edited by androidlabs; 05-06-2014 at 15:49. |
05-06-2014, 19:17 | #38 (permalink) | |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Quote:
http://forum.gsmhosting.com/vbb/9309220-post23.html | |
05-07-2014, 09:57 | #39 (permalink) |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | [QUOTE=sweet4hamza;10290847] Thanks for the reply sweet4hamza but my box is almost new are you sure this is hardware problem ? |
05-07-2014, 11:08 | #40 (permalink) | |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | [QUOTE=androidlabs;10292107] Quote:
1.try auto detect 2.custom detect 3.usb mode 4.many phones need vcc and gnd both to get pinout 4.some mtk new cpu need usb to get connection 5.some mtk need boot key to detect phone 6.some spd android dont detect u need to use android tools 7.need to install driver for phone properly for usb mode 8.p-07a and p-05b both are common ca101 port but to clip are different try one by one get boot pin 9.try to select boot file then read info 10.try rx,tx everybody know volcano is the world best tools that can detect phone so fast its true newer user got confused to operate i also faced same to every user read user guide before use read update follow success story follow post on volcano section you will be happy soon and will fell comfortable to use it br_mithun roy | |
The Following User Says Thank You to gsm mithun roy For This Useful Post: |
06-19-2014, 04:46 | #42 (permalink) |
Freak Poster Join Date: Jan 2005 Location: mexico city Age: 52
Member: 106488 Status: Offline Thanks Meter: 24 | never detect any phone and that in selft check minutes, then will give the test results . You may based on this result to determine whether the software for internal have any faults . Check Cable... no short-circuits pins User stop. ============================== System recovering... System recovery complete. ============================== Detecting motherboard... Detecting PL2303... Testing completed, nothing abnormal. ============================== Detecting upper board... Testing completed, nothing abnormal. ============================== Check Cable... no short-circuits pins User stop. >>============================== |
