08-18-2014, 00:10 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Nigeria,Lagos
Member: 275290 Status: Offline Thanks Meter: 50 | Volcano box can format (Wipe) any SPD Android without usb debug, without dead important thing is to boot the spd in fastboot mode AM USING ITEL it1500 CPU TYPE:SC7710G (THE PHONE FORMATTING IS NOT SUPPORT BY VOLCANO, ETC, AS YOU KNOW, MANY OF THIS CPU TYPE DEAD AFTER FORMATTING) LETS DO IT WITH VOLCANO. HOW TO BOOT TO FASTMODE AND WIPE YOUR SPD ? Open Volcano Tool V2.7.7 then Android Tool V2.2 then ADB MODE tap. check "Shift mode" then select Bootloader from the drop down. Power off your phone and take out Battery. put the Battery back and power on the phone then plug your usb cable immediately. when your pc detect the phone, then continue pressing "Start" button in volcano till volcano will detect the phone and boot the phone to Fastboot mode. then go to FASTBOOT tap select "Is Fastboot" and click Start to sure the phone is in fastboot >>20080823 fastboot. then select "Wipe Data" then "Start" . and select "Wipe Cache" then "Start" DONE. Select "Exit Fastboot" to reboot your SPD phone. see the SPD ITEL IT1500 SC7710G information |
The Following 4 Users Say Thank You to alhudah_1 For This Useful Post: |
08-18-2014, 01:32 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: DAVAO
Member: 2082354 Status: Offline Sonork: 564788686887 Thanks Meter: 115 | not all spd have fastboot we have pac file to wipe using any flahing tool; and not going to dead cause volcano cant asure our phone will be alive after format we are not intiligent for those procedures |
08-18-2014, 07:31 | #3 (permalink) | |
Member: 275290 Status: Offline Thanks Meter: 50 | Quote:
not these pac files:SC6820_Wipe_userdata.pac or SC8810_Wipe_userdata.pac those pac files kills (dead or blank screen) CPU TYPE:SC7710 give me pac file to format CPU TYPE:SC7710 thanks | |
11-01-2014, 12:07 | #6 (permalink) |
Freak Poster Join Date: Feb 2009 Location: algeria
Member: 982456 Status: Offline Thanks Meter: 20 | many thanks bro ihave done tablette samsung 8000 spd sc6820/8810 today withe fastboot in the first withe adb the tool show me rest gmail succes but no done . i have try withe some tools but not succes . finaly withe fastboot it work . THANKS |
The Following User Says Thank You to stgs For This Useful Post: |
11-02-2014, 12:11 | #7 (permalink) | |
Open android tool Usb mode Read flash (bin file) Enjoy Last edited by alhudah_1; 11-02-2014 at 12:14. Reason: Mistake | |
11-02-2014, 12:36 | #8 (permalink) | |
Just power on the phone and put the use cable to the phone and pc Open android tool in volcano and go to adb mode Select is adb and click start Select adb root (if not root before) and click start Then reset gmail to remove gmail lock Unlock to remove patern lock ..................... If the use debug no enable. Follow the first post (fastboot mode). ENJOY | |
11-22-2014, 04:13 | #10 (permalink) | |
Freak Poster Join Date: Oct 2013 Location: Central Igorot
Member: 2041408 Status: Offline Thanks Meter: 38 | Quote:
Not all SPD Andriod is supported with this method, I test with some phone and it will be headache, ex: DTC GT6B it will not work, and the worse is no PAC FILE for GT6b | |
12-20-2014, 16:29 | #11 (permalink) |
Freak Poster Join Date: Sep 2012 Location: NIGERIA
Member: 1817604 Status: Offline Thanks Meter: 6 | itel1500 now the phone is in fastboot mode but refuse to wipe data or wipe cache dont no what to do but the phone is not in debug mode pls help me plesssssssssssssssssssssssssssssssss i really need your help plssssssss help me sir plssssssssssssss |
12-27-2014, 12:13 | #13 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2316197 Status: Offline Thanks Meter: 0 | guys... can any one help me,,my volcano box,,its windows 7,,how can i run it in windows 7,my volcano box connected but its appears no phone connected....all connection fine,,once i use usb cable..its also appears no phone connected... thanks |
