04-27-2016, 16:32 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Made In Venezuela Age: 39
Member: 1044690 Status: Offline Sonork: 100.1617308 Thanks Meter: 56 | Volcano Box many problems [ No Screenshot of Error ]
04-27-2016, 19:57 | #3 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Post Here GUI Error Screenshot As Well As Device Manager Screenshot So We Can Check N Understand Where Is Problem N Give U Proper Solution... Br. Hi-Tech Care GPG Team |
04-28-2016, 21:31 | #5 (permalink) |
Member: 1044690 Status: Offline Sonork: 100.1617308 Thanks Meter: 56 | This image was placed with a volcano that if this good and open software ... and connect the box this bad, then there if I connect the box and give me the serial does not work and say: INVALID LICENSE DATA.THE OPERATION CANNOT BE RUNNING. |
04-29-2016, 04:29 | #7 (permalink) | ||
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
Your Problem is Not Clear to Us , Make Clear Answer Above Quotations # Volcano Tool / Utility Not Open & Error Says Volcano Box Not Found ? [ Your 1st Post ] or # Volcano Tool / Utility Not Open & Saying Invalid License Data ? if then Post Here Volcano Box Serial | ||
The Following User Says Thank You to zoneofash For This Useful Post: |
04-29-2016, 18:17 | #10 (permalink) | |
Thar Noting to Figure Out Here , It's Need to Done by You ...!! # Check Volcano Box Cable # Check Volcano Box Connector # Check You Have Installed Correct Drivers # Make Sure , Red Button [ in Volcano Box Front Side ] Unpressed # Finely Open Box & Check Short Circuit | |
04-29-2016, 20:16 | #12 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Arizona Age: 38
Member: 630795 Status: Offline Thanks Meter: 177 | hello i have the same problem with merpi tool drivers installed correctly but always Volcano box not found Can i use Volcano Smart card with any smart card reader? |
04-30-2016, 04:26 | #14 (permalink) | |
Volcano Box Not Use Smart card Security , We Use Kind a H/W & Server Based Security | |
