05-30-2013, 17:35 | #1 (permalink) |
Freak Poster Join Date: Sep 2011 Location: uganda Age: 34
Member: 1657640 Status: Offline Sonork: ayikobuam Thanks Meter: 11 | volcano box no vcc and gnd at dr26 port so it does not detect any pins for all mobiles.. can u please help me. it says vcc.... null gnd.... null rx and tx take too long main cable fine on dragon |
05-30-2013, 19:08 | #2 (permalink) | |
Product Supporter Join Date: Oct 2009 Location: Mumbai. Great India
Member: 1135304 Status: Offline Sonork: 100.1592050 QQ:3549168141 Thanks Meter: 4,071 | Quote:
2: go to system and do system recovery 3: put 9 volt charger in box back side if problem not solved this post system recovery screen shot | |
The Following User Says Thank You to king.of.gsm For This Useful Post: |
05-30-2013, 20:22 | #3 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | try can your volcano main cable and also check how much out put voltage came from box? |
The Following User Says Thank You to sweet4hamza For This Useful Post: |
06-02-2013, 18:25 | #7 (permalink) |
Member: 1657640 Status: Offline Sonork: ayikobuam Thanks Meter: 11 | VOLTAGE CHANGES FROM 1.62V 1.84V 1.95V AND DROPS TO -1.4V 0.9V AGAIN AND AGAIN SMALLEST VALUE = -1.4 GREATEST VOLTAGE = 1.95V WHEN PINOUT FIND IS OVER VOLTAGE IS CONSTANT AT 0.05V y i opened box and could this be the problem???? there is a similar chip exactly behind this one i mean on the other side of the board its labeled P74, BCP69 PLEASE HELP ME |
06-02-2013, 18:54 | #8 (permalink) | |
Member: 1657640 Status: Offline Sonork: ayikobuam Thanks Meter: 11 | Quote:
recovery is ok i also tried to short some some wires of the main cable and it is shown on the screen as this.. if i remove the short circuit the green hilight goes away and if place it back the green comes again. Does this clearly show it is only power problem???? please see my reply to sweet4hamza | |
06-02-2013, 19:41 | #9 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | if u wanna repair your box, make sure u have good skill on electron. all clue just trick on repairing that box! u can ask for help ( repair services )to Volcano box Reseller then let the technician check your box...if possible can repaired is lucky for u. and if cant u must buy the new one because your box has out of warranty or try with this trick : |
06-04-2013, 17:35 | #10 (permalink) | |
or are u asking me to replace this component(s) | |
