Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 09-20-2017, 22:54   #1 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
Volcano box not connect please help [SOLVED & CLOSED]
drivers already install please help me
Old 09-21-2017, 05:38   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
Seems you are using wrong setup
box and dongle have different setup
please check and try again
Old 09-21-2017, 20:56   #3 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
I used this box in month ago so can you please direct me to right setup
thanks
Old 09-22-2017, 08:25   #4 (permalink)
Member: 2211790
Thanks Meter: 5,118
thanks
Download setup from (Inferno activated Volcano box) Folder
Index of ./VolcanoBox/Volcano_Inferno_Updates/
Old 09-24-2017, 20:33   #5 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
after download run sw i have same result i think its a drivers problems
Old 09-24-2017, 21:03   #6 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
after download VolcanoUtility_v3.1.0_Volcano Module then extract Yellowstone inside and run its says "Volcano box not found...."
Please help me
Old 09-25-2017, 05:45   #7 (permalink)
Member: 2211790
Thanks Meter: 5,118
Please help me
check box drivers
also check box have a button that should not pressed inside
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 09-25-2017, 21:04   #8 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
check box drivers
button was pressed inside i press again to release but not release then remove screws then press and it release now box connect
thanks
Page generated in 0.17938 seconds with 9 queries
