Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Volcano Box
Old 03-27-2012, 19:57   #1 (permalink)
Member: 458253
Thanks Meter: 29
Red face volcano box not detact any phone[Solved]
plz help volcano team
my volcano box not detect any phone always show error
here is log
Volcano Updated: 2012-03-26
Connecting...
Connection successful,connected state!
Version: V3.8
SN:014-072-453
Port:COM5
Available Ports:COM5
Detection initiated, connect the phone and power on it...
Failed to detect VCC and GND, not connected to mobile phone or mobile phone is over-current.
Pinouts are not fonud!
I try this mathed but same condision
1: Remove setup Of VOLCANO BOX From Control Panel, and then remove / delete VOLCANO BOX folder (FuriouS TeaM)from Program Files, folder.
2: Delete all files from C:\WINDOWS\Prefetch Folder .
3: DOWNLOAD DC-Uninstall Device And Remove All port (FTDI) & Drivers.
4: DOWNLAOD CC CLEANER AND CLAEN UR FULL system AND RESTART PC.
5: After Restart PC, Disable Antivirus which you are using..
6: Install VERY FIRST VERSION of VOLCANO BOX. V1.05 . (keeping your antivirus still in disable mode.)
7: In your antivirus settings , select windows driver folder in Exclusion list (C:\WINDOWS\system32\drivers).
8: Connect your VOLCANO BOX. It will search driver for new hardware. Select manually from C:\Program Files\FuriouS TeaM\VolcanoBox\Drivers\Box Drivers
9: Install latest version of VOLCANO BOX. When installing driver it will ask for Overwite. press 'NO' .(Only update new version software . Leave drivers as old. it will work for you!).
10: When connected Mstar & Spd phones., install drivers manually from C:\Program Files\FuriouS TeaM\VolcanoBox\Drivers\Phone Drivers.
Old 03-27-2012, 20:13   #2 (permalink)
mobi_soft's Avatar
Member: 1126941
Sonork: 100.1672154
Thanks Meter: 2,445
its not driver problem...i
its cable problem
change main box cable....
try with flip jig pin also...
Old 03-27-2012, 20:23   #3 (permalink)
.::jagdeep-Gupta::.'s Avatar
Member: 787829
Sonork: 100.1615114
Thanks Meter: 908
Arrow
here is log
volcano updated: 2012-03-26
connecting...
Version: V3.8
sn:014-072-453
port:com5
available ports:com5
detection initiated, connect the phone and power on it...
failed to detect vcc and gnd, not connected to mobile phone or mobile phone is over-current.
i try this mathed but same condision
1: Remove setup of volcano box from control panel, and then remove / delete volcano box folder (furious team)from program files, folder.
2: Delete all files from c:\windows\prefetch folder .
3: Download dc-uninstall device and remove all port (ftdi) & drivers.
4: Downlaod cc cleaner and claen ur full system and restart pc.
5: After restart pc, disable antivirus which you are using..
6: Install very first version of volcano box. V1.05 . (keeping your antivirus still in disable mode.)
7: In your antivirus settings , select windows driver folder in exclusion list (c:\windows\system32\drivers).
8: Connect your volcano box. It will search driver for new hardware. Select manually from c:\program files\furious team\volcanobox\drivers\box drivers
9: Install latest version of volcano box. When installing driver it will ask for overwite. Press 'no' .(only update new version software . Leave drivers as old. It will work for you!).
10: When connected mstar & spd phones., install drivers manually from c:\program files\furious team\volcanobox\drivers\phone drivers.
contact your reseller check your box may be problem no one getting this problem after all procedutre check in other pc or contact me bro i will help you for any solution about volcano box
thanks
Old 03-28-2012, 05:11   #4 (permalink)
Member: 458253
Thanks Meter: 29
its cable problem
i also try flip jig pin & china 6 in 1 cable but same prob
Old 03-28-2012, 05:12   #5 (permalink)
Member: 458253
Thanks Meter: 29
thanks
i try 3 pc but same result
Old 03-28-2012, 05:21   #6 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 4,814
Bro, listen carefully
Change with the other USB A+B Cable
Not flip jig pin & china 6 in 1 cable
Regard,
Old 03-28-2012, 05:24   #7 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,519
also change position of ur + and - probe.
br
Old 03-28-2012, 07:03   #8 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 474
@Rayvikash2
the box main cable + and - wire is apposite change it and try again
Old 03-28-2012, 09:27   #9 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 70,480
kindly
do not attach any cable to box and click on run and post here screen shot
Faisal_computer
Old 03-28-2012, 10:57   #10 (permalink)
Member: 458253
Thanks Meter: 29
Regard,
i also use A+B cable but same result.......
Old 03-28-2012, 11:14   #11 (permalink)
Member: 458253
Thanks Meter: 29
Originally Posted by Faisal_Computer View Post
kindly
Faisal_computer
without connect cable screen shot
Old 03-28-2012, 11:26   #12 (permalink)
Member: 151871
can you please come to my sonork ?
100.1577177
Faisal_Computer
Old 03-28-2012, 12:07   #13 (permalink)
Member: 458253
Thanks Meter: 29
100.1577177
Faisal_Computer
plz send ur yahoo messenger id
my id is [email protected]
Old 03-28-2012, 12:41   #14 (permalink)
Member: 151871
[email protected]
add me and talk to me
Faisal_Computer
Old 03-28-2012, 12:56   #15 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 920
Check volts at supply lines
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.47800 seconds with 8 queries
