01-23-2015, 20:18 | #1 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2333782 Status: Offline Thanks Meter: 0 | Volcano Box Not Found The problem Volcano Box Not Found. Please Connect Box and Run Software Again. The work done Clear All Box Replacement windows But the problem remains Please Help |
01-24-2015, 05:33 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Change USB cable. Install proper driver for the box. If u don't use external power for volcano box, then note the switch must be in off condition. Don't use USB hub, e.g. Directly plug the USB cable to system... Br Chandan |
The Following 3 Users Say Thank You to chandanps18 For This Useful Post: |
01-24-2015, 06:39 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 238 | Hello delete Your Volcamo box drivers download this drivers install do restart and post results. Drivers - Download - 4shared |
The Following User Says Thank You to TUN10 For This Useful Post: |
01-24-2015, 09:23 | #10 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | CONTACT ME VIA SONORK WHY YOU HAVE MADE SAME POST IN FLASH FiLE SECTION ? ALWAYS POST SOFTWARE AND BOX PROBLEMS HERE IN VOLCANO BOX SECTION , AND FLASH FILE REQUEST IN FLASH FILE SECTION . |
01-24-2015, 09:36 | #11 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Kamber, Sindh, Pakistan Age: 36
Member: 1983780 Status: Offline Thanks Meter: 353 | 1, first see ur volcano on off button 2, redownload the volcano update ur problem was solved... same problem with me few days ago.... try |
01-25-2015, 07:03 | #15 (permalink) |
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 238 | Hello how are you?download please ammy and give me id Ammyy Admin - программа удаленного доступа к компьютеру, программа для удаленного управления компьютером - скачать. |
