06-21-2016, 17:07 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | 1-Check red switch on front of volcano box if its press inside than press that switch for out. 2-Check the volcano drivers in device manager if missed something 3-Check volcano box port number if its over 40 than reduce to under 20 for best result. Post result |
The Following User Says Thank You to ij_cell For This Useful Post: |
06-21-2016, 22:30 | #3 (permalink) |
No Life Poster Join Date: Apr 2015
Member: 2385655 Status: Offline Thanks Meter: 99 | volcano box not found 1-Check red switch on front of volcano box if its press inside than press that switch for out. 2-Check the volcano drivers in device manager if missed something 3-Check volcano box port number if its over 40 than reduce to under 20 for best result. Post result switch off Volcano Box Not Found Please Connect Box and Run Software Again [ Guide Here] - Volcano Box ? use pice but sem problem |
06-23-2016, 14:56 | #7 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | volcano box not found [ Answered ] Plees Conform Your Volcano Box Connected With PC correctly & Correct Drivers Installed on Device Manager 100% connected on pc how to solved my problem 1000%driver instal pc ok and chang pc and pc cable and try win8 and try winxp sem problem velcano box 2 light on open one off |
06-23-2016, 17:08 | #8 (permalink) | |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
Contact me via Skype , Ill Check This Via TV | |
06-24-2016, 15:13 | #9 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | volcano box not found [ Answered ] Check red switch on front of volcano box yes my switch off but help me IJ_CELL GPG Merapi Tool Inferno Dongle Gsm Developers TeamŽ IJ_CALL MY PROBLEM SOLVED THANKS FOR THIS MAN........ |
