03-01-2016, 11:14 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | volcano box not found any mobile on comport Available Ports:COM3 COM4 COM162 Detection initiated, connect the phone and power on it... Vcc: null Gnd: 5 Failed to detect. >>Pinouts are not fonud! its show gnd and vcc but not connect any mobile if i set manually pin out and insert battery then easily connect how to solve please |
03-01-2016, 11:29 | #2 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Hello, Did you try System Recovery .. If no then First do it .. Also do set Voltage .. Wbr, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
03-01-2016, 12:03 | #4 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Bro You Are Using Uni Jig or Rj45 Cable ? Check Cable Or Change Connection Method . |
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
03-01-2016, 12:20 | #5 (permalink) | |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Quote:
i use uni jig and com port also and i try with other box cable same result gnd and vcc found but not connect mobile if i set manually pinout and insert battery then connect easily | |
03-01-2016, 13:36 | #6 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Look Like You Have Installed Volcano Box in High Com Port , Install it to Lowe COM Port Like COM1 , COM 3 & Post Results |
The Following User Says Thank You to zoneofash For This Useful Post: |
03-01-2016, 14:05 | #7 (permalink) | |
After that the spd drivers will have the ability to be loaded. Available Ports:COM3 COM4 COM5 Detection initiated, connect the phone and power on it... Vcc: null Gnd: 2 5 Failed to detect. >>Pinouts are not fonud! | |
03-02-2016, 04:13 | #8 (permalink) | |
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
Maybe Your Serial Port Damaged Or Unconnected Correctly With PCB | |
