09-05-2015, 07:20 | #1 (permalink) |
Junior Member Join Date: Aug 2015 Location: Bangladesh, South Asia, Earth.
Member: 2449540 Status: Offline Thanks Meter: 7 | Volcano Box Not Found !!! Solution 100 % works "VOLCANO BOX NOT FOUND, PLEASE CONNECT BOX AND RUN SOFTWARE AGAIN" If you face this problem then follow this instruction below...... 1. At First Extract Volcano 2.8.3 or whatever YELLOWSTONE to any folder of your any HDD Drive. If you dont have it then just google it with following keywords, "Volcano 2.8.3 Yellowstone download" 2. Then Download Volcano Module 3.0.5. You Need exactly 3.0.5 version for avoiding this error. Google it and download if you dont have it. 3. Extract Volcano Module 3.0.5 in the same folder you extracted Volcano Yellowstone. Install Box and Mobile drivers if you didn't.. After That Connect Your Box And Run It... [And YOUR PROBLEM SOLVED ] You're Welcome |
The Following 5 Users Say Thank You to mdfuj For This Useful Post: |
05-27-2016, 05:23 | #3 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | You Can Downloaded From Here >> Index of ./VolcanoBox/ But For Volcano Box Not Found Problem is Just Drivers Issue , you can Fix it by Installing Correct Drivers |
The Following 2 Users Say Thank You to zoneofash For This Useful Post: |
08-05-2016, 17:37 | #7 (permalink) |
Freak Poster Join Date: Jun 2004 Location: jb cell world Age: 47
Member: 70916 Status: Offline Thanks Meter: 56 | box not found even driver remove and reinstall also and also change date 2 months back same issue hwo to fix it is ther any fix s/w from volcano team ? |
12-03-2016, 09:19 | #8 (permalink) | |
Junior Member Join Date: Jan 2007 Location: india
Member: 438722 Status: Offline Thanks Meter: 0 | Quote:
06-12-2018, 11:33 | #10 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1880823 Status: Offline Thanks Meter: 4 | This Worked For ME Change Port Number from Device manager to port #3 . 1.Left click on Volcano box port 2.Click on Properties 3.Port Settings>Advanced>Com Port Num>select port 3> Ok 4.Done |
08-10-2018, 08:17 | #11 (permalink) | |
Freak Poster Join Date: Mar 2006
Member: 241673 Status: Offline Thanks Meter: 8 | Quote:
tested, work for me lyk a charm thks verry mch Last edited by sixgems; 08-10-2018 at 08:23. | |
