03-10-2014, 11:11 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Dhahran ph
Member: 334094 Status: Offline Sonork: none Thanks Meter: 73 | Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:6582 Hardware version:CA01 Software version:0001 Boot downloading complete! EMMC_ID:0x1501004B3557564D42013DBB43BA903D EMMC_PRODUCT_NAME: SAMSUNG :0x4B3557564D42 EMMC_BOOT1_SIZE: 0x00200000 EMMC_BOOT2_SIZE: 0x00200000 EMMC_PRMB_SIZE: 0x00080000 EMMC_GP1_SIZE: 0x00000000 EMMC_GP2_SIZE: 0x00000000 EMMC_GP3_SIZE: 0x00000000 EMMC_GP4_SIZE: 0x00000000 EMMC_USER_SIZE: 0xE9000000 Analysis of USB port... >>Analysis of system files... |
03-10-2014, 11:33 | #5 (permalink) |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | How to solve hang problem - ----------------------------------------- First Method - Power ON your phone..and connect it to usb cable. Check in device manager, if its showing Android Phone or not. if showing, then usb debugging is enabled, Do this now - *Open volcano android tool *Go to adb mode tab *Root your device first (Tick "ADB Root" & press start) *Then (Tick "Wipe_All" & press start) *After mobile restarted.. "Unroot" your device. Check your Device Now. Second Method - if usb debugging not enabled then do with usb method *Open volcano android tool *Go to usb mode tab *Tick "Read Info" & press start button. *Power OFF phone, insert battery and then insert usb cable. (If not detected, press volume up/volume down while inserting usb cable) If On Reading Info If it gives message - "Analysis Flash internal data Successfully" then you can do format without any risk. If it gives message - "Analysis Flash internal data fail" then its risky to format the phone (Do format on your risk.) How to Format..See here - *Remove phone from USB Cable. *Format your device (Tick "Format" & press start) *Power OFF phone, insert battery and then insert usb cable. (If not detected, press volume up/volume down while inserting usb cable) *Handset will get formatted...check now Format only if you have working backup or firmware available at your collection. Third Method - if above methods failed then do flashing with working firmware. search on the forum, u'll get firmware if available. bR. Smk |
