Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 02-27-2015, 15:27   #1 (permalink)
Member: 1759693
Thanks Meter: 54
Volcano box starting problem??
Supporter sir I have a volcano box. Before it was working well on windows 7 32bit. When I Install 2.9.3 volcano module and 2.8.3 yellowstone. Initialization failed. Launching volcano box doesn't respond. Shows this problem.
Please identify and help me to find solution. Urgent
Old 02-27-2015, 15:48   #2 (permalink)
..::Qus::..'s Avatar
Member: 2335787
Thanks Meter: 149
At first Scan your hard disk with update antivirus ..............may be this virus problem
Old 02-28-2015, 05:56   #3 (permalink)
Member: 1759693
Thanks Meter: 54
Not done my friend. I think its the driver problem. But I already downloaded latest driver but not working.
Old 02-28-2015, 06:36   #4 (permalink)
zoneofash's Avatar
Member: 1445819
Thanks Meter: 4,976
Smile
No Its Not a Drivers Problem ... you Need to Disable Your Antivirus and Reinstall Volcano Setup and Drivers After Add Volcano to Antivirus Exception List !! your Problem Solve
Old 02-28-2015, 07:46   #5 (permalink)
Member: 1759693
Thanks Meter: 54
I have done this process too. I tried before installation of antivirus. No success. Same problem. Any other idea..
Old 02-28-2015, 07:58   #6 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Hello try connect another pc if open then need change Your pc os and also try open as admin.
The Following User Says Thank You to TUN10 For This Useful Post:
Old 02-28-2015, 12:57   #7 (permalink)
Member: 1759693
Thanks Meter: 54
You people seem to be very helpful. I appreciate to all and job is done well.
Old 02-28-2015, 16:17   #8 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
I am wery glad dear friend to see that Your pb have solved anly can You tell me wich solushion You have use?
Old 03-01-2015, 03:58   #9 (permalink)
Member: 1759693
Thanks Meter: 54
Normally I used to run volcano without "run as administrator". It directly opens. Yes it is right that while installing volcano box antivirus shows this as virus. Disabling it and running installation would be the right thing. I run as administrator and work well.
Page generated in 0.19367 seconds with 9 queries
