09-06-2014, 06:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2009
Member: 1051835 Status: Offline Sonork: 100.1594332 Thanks Meter: 514 | Volcano cannot flash Qmobile X5 Volcano box is not able to flash Qmobile X5, When I try to do so, its stops on baud adjustment and cannot write flash file. Help me please. I want to write its imei. Imei is invalid after I format X5. |
09-06-2014, 06:54 | #5 (permalink) |
No Life Poster Join Date: Jul 2012 Location: GSMFABRICA-Team Age: 35
Member: 1785930 Status: Offline Sonork: 100.1685640 Thanks Meter: 4,780 | CHECK THIS FLASH aftyer flash post result TINNO36_10A_GEMINI_BOOTLOADER_V005_MT6236_EM890_PP _F1_PK_56M_F7_V005(2) br, unlockinfo |
09-06-2014, 06:54 | #6 (permalink) | |
Member: 1051835 Status: Offline Sonork: 100.1594332 Thanks Meter: 514 | Here is the info. Please check and let me know what is the problem happening with me. Quote:
09-06-2014, 07:14 | #12 (permalink) |
Member: 1785930 Status: Offline Sonork: 100.1685640 Thanks Meter: 4,780 | bro step by step use procedure 1: MTK tab 2: Illagal imei 3: connect phone on with usb cable and select usb port 4: open write imei and select port 5: write phone original imei back side and clik write imei i hope your problem solve br, unlockinfo |
09-06-2014, 07:31 | #14 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | @~The JoKeR~ Find factory Firmware then your problem solved otherwise write any file your phone Not Powered On. BR Qaisar Mahmood |
