Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 01-12-2013, 03:59   #1 (permalink)
Member: 227348
Sonork: yolem053
Thanks Meter: 44
cherry mobile c2 after writing flashfile no network.
first of all the problem was only lcd, i replaced the lcd because it has lines and already blurred
after replacing the lcd the phone is working well but the color of the screen is blue not the usual red color of cherry mobile logo and it's menu, because the lcd is just a replacement and not original.
so i decided to flash the phone with my files readied from same phone, just like i did with cherry mobile D11 when the lcd display is blue i just to flash it to return to its original color.
after the flash procedure i write the orginal IMEI but to my surprise the phone has no network sometimes emergency only
i wrote back the original files and it works well and has a signal but the screen is blue.
any idea???
Old 01-12-2013, 05:33   #2 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
Its possible that the other file does not match on your mobile, just my guess, How about other files? If that's the case best option is to put an original LCD.
Old 01-12-2013, 05:41   #3 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
restore nv !!!!!!!!!!!!!
Old 01-12-2013, 05:49   #4 (permalink)
Member: 1861521
Thanks Meter: 20
restore nv brother....................
Old 01-12-2013, 09:26   #5 (permalink)
Member: 227348
Sonork: yolem053
Thanks Meter: 44
i already tried 8 files from the same cherry phones, same result no network, restore nv no luck.
any idea?
The Following User Says Thank You to yolem053 For This Useful Post:
Old 01-12-2013, 09:27   #6 (permalink)
Member: 227348
Sonork: yolem053
Thanks Meter: 44
i already did that but no luck.
any idea?
Old 01-12-2013, 10:11   #7 (permalink)
Member: 226457
Sonork: No more used
Thanks Meter: 14,934
@yolem053
try this method
1-write backup
2-Read cnv From general parameter
3-Do write flash
4-write cnv From general parameter
Qaisar Mahmood
The Following User Says Thank You to Qaisar Mahmood For This Useful Post:
Old 01-12-2013, 10:12   #8 (permalink)
.:TithiMobile:.'s Avatar
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
if u have use flash tool and read working phone flash with flashtool and write in this faulty set and then check
The Following User Says Thank You to .:TithiMobile:. For This Useful Post:
Old 01-16-2013, 13:10   #9 (permalink)
Member: 227348
Sonork: yolem053
Thanks Meter: 44
i found out that cherry mobile c2 has two versions, the c2 and the c2 v2.0, we can identify it by looking the stickers at the back of the battery.
now i only have a back up of the first version of c2, and if you flash it to version 2, the mobile will turn-on but it says "message memory is full" and it has no network despite writing back the original NV to the phone.
im asking my co-members in this forum; please share me a flashfile for cherry mobile c2 version 2.0
thanks in advance.
Old 03-05-2016, 08:29   #10 (permalink)
Member: 2539307
Sonork: 01840144926
hellow all my gsm friends
Page generated in 0.15796 seconds with 8 queries
