Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 10-02-2014, 08:49   #1 (permalink)
Member: 665025
Thanks Meter: 44
volcano team, spd write always error,. pls help,...
device: skk mobile A3, blinking,.
read flash done,..
write backup bin not done
write other tested bin file not done,.
ive used volcano v1.9.6, v2.3.8, v2.4.7, v2.6.9, v2.8.2,. all same result..
Volcano Updated: 2014-09-16
Connecting...
Connection successful,connected state!
Version: V3.8
SN:
Port:COM47
After format or Flash you have to press & hold power button for at least 1.30 mins.
Note for win7 users :
Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'.
After that the spd drivers will have the ability to be loaded.
Available Ports:COM1 COM47
Detection initiated...
Vcc: null
Gnd: 5
Analyzing D+ and D-...
D+ = 3, D- = 2
Analyzing USB device, please wait...
Find USB device:SPRD U2S Diag (COM48), (VID_1782&PID_4D00)
Internal version: SPRD3
Boot downloaded.
Start boot please wait a moment....
Spreadtrum Boot Block version 1.1
>>Ready to read/write again, please remove the power supply clip or battery and then re-loaded it.
pls help,.. reading went well
Old 10-02-2014, 10:25   #2 (permalink)
Registered User
Member: 632643
Thanks Meter: 74
if you have the backup,then flash it via SPD factory flasher using your readed flashfile...
if not flashfile here SKK A3
password : smartclip
Old 10-02-2014, 10:27   #3 (permalink)
MUKESH RAJ's Avatar
Member: 1084080
Thanks Meter: 8,114
read flash done,..
Try with Volcano Box Android Tool
than post Result
BR,
MUKESH RAJ
Old 10-03-2014, 02:25   #4 (permalink)
Member: 665025
Thanks Meter: 44
already used this file but always stuck at:
also used android tool, same result...
Old 10-03-2014, 02:40   #5 (permalink)
Member: 665025
Thanks Meter: 44
Connecting...
Version: V3.8
SN:593-476-473
Port:COM47
Current Port:COM47
Analysis of USB port,Please insert phone USB cable.
Boot downloaded.
stuck here,.. pls heeeeeellp,...
can somebody create pac file using "culo"s firmware?
ive flashed another pacfile but calibration wont work,..
the only tested file i have is the bin file which ive got on other ste,..
Old 10-03-2014, 03:15   #6 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
read flash done,..
Connecting...
Version: V3.8
SN:
Port:COM47
Vcc: null
Gnd: 5
D+ = 3, D- = 2
Boot downloaded.
use old version like 259.
Old 10-03-2014, 03:20   #7 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
read flash done,..
Connecting...
Version: V3.8
SN:
Port:COM47
Vcc: null
Gnd: 5
D+ = 3, D- = 2
Boot downloaded.
Old 10-03-2014, 03:44   #8 (permalink)
Member: 665025
Thanks Meter: 44
ok ill try 2.5.9
edit: used 2.5.7, same result,..huhuhuhuhuhuhuhuhuhu
Old 10-03-2014, 04:03   #9 (permalink)
Member: 665025
Thanks Meter: 44
still no luck with version 2.5.7 and 2.5.9
can somebody convert this file from bin to pac file?
skk a3 524mb - Download - 4shared - alex domato
plssssssssssssss
ive flashed this pac file, good but only touchscreen wont work, heres the pac file:
http://www.4shared.com/rar/1VkdHgTFb...parekx_25.html
Old 10-03-2014, 07:13   #10 (permalink)
Member: 665025
Thanks Meter: 44
up up up,.. pls heeeeeelpp,...
Old 10-03-2014, 07:47   #11 (permalink)
Crazy Poster
Member: 1192716
Sonork: Lucnow
Thanks Meter: 5
Gnd: 14 22
D+ = 18, D- = 17
Detection D+/D- with 1.72 seconds.
Continue to detect BOOT pin...
Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
BOOT(Pull Down) = 15
Setting...
Find USB device:SCI USB2Serial (COM19), (VID_1782&PID_4D00)
Pinouts setting complete!
Boot downloaded.
The 1st boot failure,Please reduce Baud-rate and try again!
Please change Boot or reduce Baudrate, try it again.
cpu spd6610 readinfo not work any virsion help me
Old 10-04-2014, 03:08   #12 (permalink)
Member: 665025
Thanks Meter: 44
up up up,.. can somebody pls convert this file to pac file,..
Old 10-04-2014, 05:31   #13 (permalink)
laxmi kamlesh's Avatar
Member: 1873645
Thanks Meter: 977
@markrempillo
.bin to .pac convert is not possible.
The Following User Says Thank You to laxmi kamlesh For This Useful Post:
Page generated in 0.26457 seconds with 8 queries
