Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Volcano Box
Old 06-20-2013, 18:51   #1 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 70,569
VolcanoBox 2.1.8 Verification System for SPD Android &MTK6260 Read/Write/Imei/Privacy
VolcaoBox 2.1.8
Whats new ?
World's 1st Added SPD Android Verification system
World's 1st Added SPD Android Verify your phone is Safe for format
World's 1st Added SPD Android Verify your phone is Safe for Root
World's 1st Added SPD Android Verify your phone is Safe for READ INFO
Added MTK 6260 Read Flash
Added MTK 6260 Write Flash
Added MTK 6260 Imei Repair
Added MTK 6260 Read privacy code
Adjust MTK Android One-key Root(Solve some phones failed to root)
Adjust coolsand Read flash bug
Read Instructions VERY CARE FULLY !!
About this Update Please Read very Care Fully before you operate any operation !!
VolcanoBox 2.1.8 Launched world's 1st SPD Android Verify Partitions System. for this Function you can Verify you mobile is SAFE for ROOT or Format or Read info. for this you must have Mobile in Powered ON condition & with Usb Debug mode ON !!. What you have to do it Simply Plug usb cable and click on Partition from Volcano soft and run it. it will tell you is your Phone Supported for SAFE format / ROOT etc or not. If software tell you is safe it will become log in GREEN color and if software tell you is not safe it will show you log in RED color. so here we start...
If software software show you log like this in GREEN COLOR.... This mean your phone is Supported for SAFE Root, format etc..
Partition as follows. It's supported to format and ROOT the mobile phone.
>>mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjaluna),10m(modem),3840k(fixnv),3840k(backupfixnv),5120k(dsp),3840k(runtimenv),10m(boot),10m(recovery),200m(system),190m(userdata),60m(cache),256k(misc),1m(boot_logo),1m(fastboot_logo),3840k(productinfo),512k(kpanic)
If software show you log like this in RED COLOR.... This mean your phone is NOT supported for SAFE Root, Format etc...
Partition as follows. It's NOT supported to format and ROOT the mobile phone.
How to do it ?
Download & Run 2.1.8
click on SPD
Select 6820
Select One Key Root
Select Partition
untick auto pinout
Plug normal usb cable to mobile in powered on condition
Usb debug must be Enabled
Click on run.
wait few sec it will Show you Logs as i describe above
Q: what is usefull if phone have pattern lock or any other problem and it have not usb debug Enabled then this option is useless how we can do that ?
A: Yes it's true that if phone have pattern lock or any other problem and usb debug not Enabled this function is really useless but infact it's not useless. many time we can't found factory files and many time Same working phone we can get from market so here is hint . Take same working phone, Should be 100% same, plug phone with usb and check is it Safe to format or not. if it's safe then you can do it without any problem and if phone is not safe then you simply don't do. so basically we make this function just to verify is phone is SAFE for format, Root etc or not...
Q: I plug phone but software not recognized or Software hang on "<<" then what to do ?
A: Perform these Steps
MAKE SURE YOUR PHONE IS CONNECTED IN POWERED ON CONDITION AND USB DEBUG ENABLED AND ADB ANDROID DRIVERS ARE INSTALLED AND YOU CAN SEE ADB ANDROID PHONE IN DEVICE MANGER !!!!!!
go to start
go to run
type "CMD"
clck on run
( go to Volcanobox 2.1.8 Folder/Tools ) for exmaple you have Volcano 2.1.8 in C: Drive so you should type this these commands. ( write all command without "" and right after every command you should press Enter button from keyboard)
"C:\" ( Press Enter )
it will become here
C:/>
then type
"cd VolcanoTool_v2.1.8\tools" ( Press Enter )
it will become here
C:/VolcanoTool_v2.1.8\tools>
then type
"adb devices"
now check what it's show to you
if it's show like this
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
List of devices attached
this mean your phone is not detecting by your computer's ADB.exe
19761202 device
This mean your phone is detect by your computer's ADB.exe
Type this command
"adb kill-server" ( press enter button )
and again
so here you have to do totally two different ways to work with it.
so we will start
if you phone not detecting by your computer's ADB.exe then you have to do this
Keep phone connected
go to ( in windows Explorer )
C:\Documents and Settings\"Your name"\.android ( Your name should be your profile name here for exmaple "Jhon", "Anglina" etc )
there you can see some files
check do you have "adb_usb.ini" file in that folder or not
If you have then open it in note pad if not then create new file named "adb_usb.ini" and save it.
Be sure you save .INI extension not safe in any other format
for confirm open C: Drive in Windows Explorer
go to Tools
click on Folder Options
click on view
Untick Hide extension for known file type
click on ok
now see that file is exactly "adb_usb.ini" be sure it's not "adb_usb.ini.txt" etc
so as you done open it in note pad, ( if you already have this file then don't create new one just open it )
type this in new line and save it
"0x1782" ( write without "" )
so after you save file
open CMD again ( which already opened previously )
Type these commands
and again
now type
"adb devices" ( press enter button )
now it should show like this
19761202 device
now you are ready to go.
so right after this disconnect phone and connect it again and type these commands
"adb kill-server" ( press enter )
"adb device" ( press enter )
as it's show
19761202 device
Keep this CMD open and go to Volcanobox and perform these steps to know is my phone Supported for SAFE format or not !!
click on SPD
Select 6820
Select One Key Root
Select Partition
untick auto pinout
click on run
now it will show you your phones details in just 1 sec
after you can do what ever you want !!
so from now no more SPD ANDROID PHONE WILL BECOME DEAD IF YOU VERIFY IT BEFORE FORMAT OR ROOT.... Keep in mind we had tested over 110 phones non of phones become dead while verifying !!
Very special Thanks to Stanner
The Following 132 Users Say Thank You to Faisal_Computer For This Useful Post:
Old 06-20-2013, 19:00   #2 (permalink)
akashrana_sky's Avatar
Member: 1220933
Sonork: 100.1590184
Thanks Meter: 471
"VOLCANO BOX " team
i want to say ................
how long time work for new update.....?
full time? unbelievable!!!
No any box team who work like Volcano box team!
really great!!!!! wonderful!!
we like it... and always with you!
thanks Volcano team.. thanks
The Following 7 Users Say Thank You to akashrana_sky For This Useful Post:
Old 06-20-2013, 19:29   #3 (permalink)
Member: 151871
Originally Posted by akashrana_sky View Post
"VOLCANO BOX " team
Thanks to Br Faisal for his humanity for helping people at needed time
You can feel from this thread how many hours I work
And thanks for your words
Faisal_Computer
The Following 24 Users Say Thank You to Faisal_Computer For This Useful Post:
Old 06-20-2013, 19:45   #4 (permalink)
laxmi kamlesh's Avatar
Member: 1873645
Thanks Meter: 968
We Are Trust On Our Hardwork.......We Don't believe in miracle.
And some Good news comming in flash file section soon...
The Following 5 Users Say Thank You to laxmi kamlesh For This Useful Post:
Old 06-20-2013, 19:55   #5 (permalink)
umo
Member: 484190
Thanks Meter: 6
how can i buy online.am in Nigeria
The Following User Says Thank You to umo For This Useful Post:
Old 06-20-2013, 20:00   #6 (permalink)
Member: 151871
You can buy from GSMSP | Online Hard Discount
Faisal_Computer
The Following 2 Users Say Thank You to Faisal_Computer For This Useful Post:
Old 06-20-2013, 20:01   #7 (permalink)
sahilfency's Avatar
Member: 1212231
Sonork: 100.1611130
Thanks Meter: 162
Verry good update
So many spd phones come in the market once thanaffter disappear
Like rokea android phones
So how to recovere this type of phones
We request you r team plz add it
Old 06-20-2013, 21:35   #8 (permalink)
Member: 118691
Thanks Meter: 5
The Following 5 Users Say Thank You to vision_cell For This Useful Post:
Old 06-20-2013, 22:54   #9 (permalink)
Member: 1123868
Thanks Meter: 11
????????????????????????? Mstar formate ( 6832 ) ??????????????????????????????
Old 06-20-2013, 23:38   #10 (permalink)
JuankyGsm's Avatar
Member: 1182337
Sonork: 100.1621795
Thanks Meter: 107
Good Update Team Volcano.!
Please ADD For SPD Android 6820/8810
Read/Write/ Flash Please.
Thanks-.
The Following User Says Thank You to JuankyGsm For This Useful Post:
Old 06-21-2013, 00:39   #11 (permalink)
snak2's Avatar
Member: 1510086
Thanks Meter: 67
sir we need flase file support section ...........own support for china fones file............
Old 06-21-2013, 01:09   #12 (permalink)
.::jagdeep-Gupta::.'s Avatar
Member: 787829
Sonork: 100.1615114
Thanks Meter: 908
Thanks-.
its under test after ready team will announce keep patience soon more hot news on the way
The Following 5 Users Say Thank You to .::jagdeep-Gupta::. For This Useful Post:
Old 06-21-2013, 02:53   #13 (permalink)
-=C.J.S=-'s Avatar
Member: 669596
Sonork: 1657504
Thanks Meter: 109
What About The SPD 6530A Sir,, Any Updates???
Regarding 50% Stop Flashing..............
We Need That Updates Fixed....i Have This Kind Of Chip Now, As Pending.
Waiting For That Update???
Advanced Thanks..........
The Following 3 Users Say Thank You to -=C.J.S=- For This Useful Post:
Old 06-21-2013, 03:01   #14 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 106
Is Volcano downgrading?
I've made a test on this new spd verifying feature but it's been failed. I used a common sc6820 phone, the Feiting N9300 because I have the appropriate factory pac file for this modell.
This phone has been failed on verifying. Ok, I couldn't risk this device so I made a try on boot root. I processed two attempts without success. Nothing happened.
Then I loaded Volcano V2.1.6 and voila, that could successfully root this phone. The phone has been rooted and works perfectly.
On the other hand, V2.1.6 won't brick an sc6820 phone regardles of it can be rooted or not.
The Following 3 Users Say Thank You to bencebacsi For This Useful Post:
Old 06-21-2013, 04:37   #15 (permalink)
ivanrommel's Avatar
Member: 144777
Sonork: 100.111515
Thanks Meter: 99
hoping to release soon....
The Following 2 Users Say Thank You to ivanrommel For This Useful Post:
Page generated in 0.42674 seconds with 7 queries
