01-31-2014, 11:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | VolcanoBox 2.5.0 Alcatel Unlocking , Read flash, Write Flash, Format, Wipe &much more VolcanoBox Team Happy to Introduce you The MTK Alcatel Module !! Whats new ? Added Mtk_Android_Tool in Android Tab Added These Models for Service -----Alcatel------ OT-4030 OT-4030A OT-4030E OT-4030X OT-4030D OT-5020 OT-5020D OT-5020E OT-5021 OT-5035 OT-6010 OT-6010D OT-6030 OT-6033 OT-6040 OT-7025 OT-8020 VF-875 VF-875X VF-975 OT-997 OT-997D OT-S500 OT-S600 OT-S710 OT-S800 OT-S810 OT-S820 OT-S850 OT-S950 -----ZTE------ ZTE V793 ZTE V889M ZTE V807 ZTE Blade C Added in Main Tab of Mtk Android Tool V1.11 Firmware Settings Detailed info about Firmware Enable/Disable Ver check Enable/Disable Format Before Flash Enable/Disable MD5 Checsum Flash Check Enable/Disable High Speed Flash Check for Auto Reboot after Flash Enable/Disable Preloader Boot Enable/Disable debug log Enable/Disable Display Boot Info Boot Info Write Flash Reset Phone Added in Unlocking Tab of Mtk Android Tool V1.11 Enable/Disable Is phone with Dual sim Reboot Phone in advanced Meta Read Codes in advanced Meta Read Code Direct Unlock Enable/Disable Clean Boot Added in Service Tab of Mtk Android Tool V1.11 Format Phone ( Custom ) Read Flash ( Custom ) Dump Phone ( eMMC ) Enable/Disable UserData Read Sinc Simlock Imei Write 1 Imei Write 2 Imei Write 3 Imei Write 4 Enable/Disable Calculate CHK Enable/Disable Clean Boot Enable/Disable Sync Simlock Read NvRam Write NvRam Index of ./VolcanoBox/Full Installer/ Full Installer Released in PARTS ( 150 MB each ) Use 7zip No more Mirror Links !! << Help Manual >> How to flash firmware? 1. Download from support firmware package. ( will upload soon ) or ( read flash file from phone ) 2. Click open scat file and select scat from firmware directory. 3. Open firmware setting and check if selected all files. 4. Reinsert battery, click write flash and insert usb cable. 5. Wait untill ready. 6. Reinsert battery and start phone (recommended first start without sim card). How to wipe phone ? 1.Press reset phone(user stuff will gone). On alcatel emmc phones this also reset code counter. Alcatel android have damaged imei, how to solve? 1.Usually flashing help in this case. Alcatel phones have imei in otp and if NVRAM become corupted, it will be autogenerated after flash. 2.If this not help, posible your phone have hardware damage(modem part). How to format phone? (advanced only) ? 1. Click boot info. 2. From displayed partitions choose needed partition start and length. 3. Click Format phone and insert values(hex or dec). 4. Click format. P.S. Don t format preloader, if preloader is formated, will need to make tp to get phone alive. How to read flash ? 1. Click boot info 2. Select needed partition start and length 3. Press read flash and fill ad*******. 4. Press read. How to dump phone.? 1.Only EMMC phones supported for dumping. 2.To make memory backup press dump phone button. Userdata have very big size, please consider this when start dump phone. 2.Nand phones not supported for dumping. How to unlock phone? (Read Codes) 1. Select model from list. 2. Click Read Codes P.S. For this operation need special(CDC) driver to be installed manaully. Download driver from support and install if PC ask for this driver. P.S. Please note, do not play with preloader. Phone can be maked alive from any state if preloader not touched. Enter engeneering menu *#*#3646633#*#* Known problems: 1. Phone stuck on logo or restart on boot screen = Reflash phone. 2. Phone work ok but no network. 2. 1 Check IMEI. 2. 2 Check different firmwares, possible not math gsm module with firmware. 2. 3 Corupted modem file, flash phone. 3. Phone work ok, but no imei. 3. 1 Flash phone, possible need to check different firmwares. If modem file is for different hardware revision result will be no IMEI also. Last edited by Faisal_Computer; 01-31-2014 at 11:32. |
The Following 112 Users Say Thank You to Faisal_Computer For This Useful Post: |
01-31-2014, 11:32 | #2 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Pakistan
Member: 1726229 Status: Offline Thanks Meter: 223 | Dear faisal bro my box not asign with server HI DEAR BROTHER PLZ SOLVE MY PROBLEM http://forum.gsmhosting.com/vbb/f723...769-a-1772237/ BOX_39764: Invalid device information. error: 769 Box serial no 297-646-334 |
The Following 6 Users Say Thank You to Ahsaan* For This Useful Post: |
01-31-2014, 11:47 | #5 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Searching....
Member: 1442705 Status: Offline Thanks Meter: 1,061 | volcano ahead of all Faisal bro.Please add firmwares in volcano box support area Last edited by Absar_Global; 01-31-2014 at 11:57. |
The Following 11 Users Say Thank You to Absar_Global For This Useful Post: |
01-31-2014, 12:05 | #8 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | 1-Read flash=It will make .img? 2-Repair imei = Why a hard reset restore orignal imei and some times null? 3-Repair imei in volcanoo by new method is patching boot I think.. Why don't you support it by factory mode? Like dragon did... |
01-31-2014, 12:34 | #12 (permalink) |
Major Poster Join Date: Dec 2012 Location: P@K!$T@N
Member: 1849288 Status: Offline Sonork: 100.1592356 Thanks Meter: 14 | facing a problem in window 7 not able to repair imei in Android Noir A8 mobile faisal bro if u have any solution so please tell me how i repair imei. and thanks |
01-31-2014, 12:43 | #14 (permalink) |
No Life Poster Join Date: Dec 2005 Location: KARACHI PAKISTAN Age: 45
Member: 207561 Status: Offline Thanks Meter: 820 | Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100040] Flash ID: 00AD00BC90555400 Flash Type:[Hyundai] NAND_HY27UT088G2A FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 190m(system),200m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic),512k(simlock) Analysis flash internal data successfully. Reset USB device and search it... Find USB device:SPRD U2S Diag (COM22), (VID_1782&PID_4D00) and write file to Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00AD00BC90555400 Flash Type:[Hyundai] NAND_HY27UT088G2A FLASH LEN:0x20000000............... Erorr.......... Please read the phone partition. >>Ready to read/write again, please remove the power supply clip or battery and then re-loaded it.??????????????????? please help me Volcano box |
The Following 2 Users Say Thank You to love_4all For This Useful Post: |
01-31-2014, 12:45 | #15 (permalink) |
Freak Poster Join Date: Feb 2010 Age: 40
Member: 1227113 Status: Offline Sonork: [email protected] Thanks Meter: 7 | sir please tell me how to repair imei in karbonn titanium s5... |
The Following 4 Users Say Thank You to ashu123456 For This Useful Post: |
