Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 04-23-2014, 10:21   #61 (permalink)
nf6_tony's Avatar
Member: 694443
Thanks Meter: 64
removed read password and imei from all spd tabs functions sounds unusual, maybe team will restore this button since format sometimes too risky...
Old 04-23-2014, 12:19   #62 (permalink)
Member: 1420901
Thanks Meter: 20
Pls add china tablet flash support.I think it will be so much appreciated.
The Following User Says Thank You to NUR ISLAM For This Useful Post:
Old 04-23-2014, 14:40   #63 (permalink)
Member: 881000
Sonork: 100.1614181
Thanks Meter: 9
Good update add htc s-off recovery installer
Old 04-23-2014, 16:04   #64 (permalink)
Member: 1242311
Sonork: 1618004
Thanks Meter: 8
YXTEL G905 on and off after format
Old 04-23-2014, 18:12   #65 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
Originally Posted by sojib744 View Post
bangladash mobile walton gh imei repair plz help
what chip inside the phone ????
Old 04-23-2014, 18:56   #66 (permalink)
Member: 1781456
Question please fix these problem
Internal version: SPRD3
Boot downloaded.
Start boot please wait a moment....
Spreadtrum Boot Block version 1.2
CPU TYPE:SC6531 [65310000]
FLASH ID: 00EF004000160000
Flash Type:[WinBond] W25Q32BV
when read flash file the phone dead via volcano v.2.6.2 or v2.6.0
while other v2.5.6 and befor device not dead
Old 04-24-2014, 07:00   #67 (permalink)
OTIENOJULIUS's Avatar
Member: 898387
Sonork: 1000.2
Thanks Meter: 103
as for me I still believe that there is no proper solution for spr6531,it's just gambling and very risky....I've killed five phones just because I always try solutions given by forum members.......I'll keep waiting.
Old 04-24-2014, 07:09   #68 (permalink)
Member: 184803
pleas 4sherd link add
Old 04-24-2014, 07:11   #69 (permalink)
Suja786's Avatar
Member: 1773058
Thanks Meter: 64
Faisal_Computer, why are you remove 'Read info' from SPD tab. Very problem of that, also spd android have Read info. But normal spd cpu Read info is a vaital funcations. Many time i success read password but hear (new update 2.6.2) remove that . But why ? What is the resions ? If i get this 2 funcations we nee to other china too. I hope next update add this .
Old 04-24-2014, 07:23   #70 (permalink)
Suja786's Avatar
Member: 1773058
Thanks Meter: 64
spd cpu read info & read password remove
Originally Posted by Faisal_Computer View Post
read info not removed from Android SPD
Old 04-24-2014, 09:07   #71 (permalink)
Member: 207561
Thanks Meter: 820
Help and salution please .For Unlock Samsung S5839i.........?????
Model Selected : s-5839i
Found Device...90003587eb27
Model: s-5839i
BOARD ID: s-5839i
PLATFORM ID: s5pc110
OS VERSION: 2.1-update1
BUILD ID: ECLAIR
BUILD DATE: 2010. 06. 05. (ي†*) 21:39:59 KST
BUILD VERSION: ECLAIR
SOFTWARE VERSION: I9000JPJF4
IMEI: 354781043237707
(GSM)RIL VERSION: Samsung RIL(IPC) v2.0
(GSM)BASEBAND: I9000JXJG2
(RIL)SALES CODE: FTM
(RIL)SW VERSION: I9000JXJG2
(RIL)(RIL)HW VERSION : MP 0.800
Checking Root access: false
Uploading Exploit data...
Rooting phone please Wait..
Waiting For Phone To Reply IF THIS TAKE LONG Then Reconnect Phone Cable And Verify Driver...
Checking Root access: True
EFS PARTITION PRESENT.
Backup saved :
D:\BOX\31-VOLCANO\VolcanoTool_v2.6.2\samsung_backup\samsung s5839i
Simlock Data not found please send backup to team for check...................
Old 04-24-2014, 09:21   #72 (permalink)
Member: 865650
Sonork: mobileworld.roorkee
Thanks Meter: 10
Please solv my problume
MTK6260 cpu
Write 16mb file
error after 55%
i try 4 other files but same candition
model lava 135 mtk6260 cpu
Old 04-24-2014, 11:08   #73 (permalink)
Member: 1087145
Thanks Meter: 162
Ps. For using SPD6500 You must install Latest SPD driver to avoid "Send error & software close"
I need SPD driver.
Old 04-24-2014, 13:22   #74 (permalink)
Member: 1822651
Sonork: 010203040506
mix update? because removing options on spd tab?
hard to understand! removed from SPRD options tab??
now how to read and remove the password spd 6530 6531 etc. ....????
after with updating is possible to use previous versions?
please!! q I believe not only over the world awaits the response of lords!!!
aguardo resposta!
thank you!
blumenthal_davi
from Jamaica (Kingston)
Old 04-24-2014, 14:38   #75 (permalink)
shoukatms67's Avatar
Member: 1974704
Sonork: 100.1641239
Thanks Meter: 20
thanx for nice update plz add alcatel model like ot 4010x thanx
Page generated in 0.23775 seconds with 9 queries
