Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871
Thanks Meter: 71,421 | VolcanoBox Inferno UniTool 1.4.1 Huawei Modems & Custom Partition by Logical Block What's new in VolcanoBox Inferno UniTool 1.4.1
- Added New way to Manage Custom Partition by Logical Block Address for Advance Users only !!
- Added Erase for Huawei E8372h-153 -> 21.313.xx.xx.306
- Fixed some VIVO phones not detecting by selecting Auto cpu.
How to Unlock Huawei Modems with Inferno ? - Open Inferno UniTool 1.4.1
- Go to Huawei -> Modem
- Connect Huawei Modem in usb
- in Normal mode
- make sure you have installed Correct Drivers
- Check software ver inside your modem.
- go to back and select Erase and then select carefully your Modem model & Firmware ver
- Firmware ver you checked from Read Info.
- Check List Below which Modem & Ver Required Erase
- Check List Below which Modem & Ver Required Testpoint
- you can download all Test Points from here ****************************/folder/ysz...ems_Test_point
- Make Sure in Device Manger have one Huawei port !!
- Write Huawei Modem Port number into Unitool Erase windows and click on next. it will Erase successfully.
- it will automatically reboot after successfully Erased
- in device manager it will show 2 ports after successfully Erased.
- Go to Huawei -> Modem -> Patch flash -> Select Modem Model & Firmware ver
- Select Same Modem & Firmware ver which you selected while Erasing & which was in modem before erase.
- click on Next and let it patch flash.
- After Patch Flash success, please look at list what operation needed for POST PATCH Flash.
- Some Modems need to Unlock by Inferno Unitool Unitool. V4 Unlock button. after patch flash
- Some modems need to repair Imei by Inferno UniTool
- Some modems need to Code calculate.
- You must update your modem Firmware to LATEST Firmware to run super fine.
- Make sure you Repair Wifi
- Kindly have a look at list below for each modems model.
- You have to Download HWModem.sys and Place into Inferno Unitool Folder
Complete Details of each ver & steps you have to do while unlock - Model: E5330s-B2
- Supported Ver: 21.210.21.xx.274
- Test Point: No
- Erase: No
- Patch Flash: Yes
- Unlock Command: No Need
- Imei Repair Command: No Need
- Note: After Patch Flash User Have To Calculate "Huawei Modem V3" Unlock Code from VolcanoBox 3.1.0 or from any website and enter into Modem by putting Wrong Sim Card into Modem.
- Model: E5330s-B2
- Supported Ver: 21.210.21.xx.306
- Test Point: No
- Erase: No
- Patch Flash: Yes
- Model: E5330s-B2
- Supported Ver: 21.210.21.xx.1065
- Test Point: No
- Erase: No
- Patch Flash: Yes
- Model: E5330s-B2
- Supported Ver: 21.210.25.xx.274
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Note: Make Patch Flash Twice
- Note2: After Patch Flash User Have To Calculate "Huawei Modem V3" Unlock Code from VolcanoBox 3.1.0 or from any website and enter into Modem by putting Wrong Sim Card into Modem.
- Model: E5330s-B2
- Supported Ver: 21.210.25.xx.306
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E5330s-B2
- Supported Ver: 21.210.25.xx.1065
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E8231-S1
- Supported Ver: 22.618.13.xx.274
- Test Point: No
- Erase: No
- Patch Flash: Yes
- Model: E8231-S1
- Supported Ver: 22.618.13.xx.1065
- Test Point: No
- Erase: No
- Patch Flash: Yes
- Model: E8231-S1
- Supported Ver: 22.618.13.xx.306
- Test Point: No
- Erase: No
- Patch Flash: Yes
- Model: E8231-S1
- Supported Ver: 22.618.17.xx.274
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E8231-S1
- Supported Ver: 22.618.17.xx.1065
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E8231-S1
- Supported Ver: 22.618.17.xx.306
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E5573cs-609
- Supported Ver: 21.318.xx.xx.274
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Unlock Command: at^nvwrex=8268,0,12,1,0,0,0,2,0,0,0, a, 0,0,0
- Note: After Patch Flash, User have to Enter "Unlock Command" from "Dc Unlocker" & then Update Firmware to which has in Modem before Erase.
- Supported Ver: 21.323.00.00.274
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E8372H-608
- Supported Ver: 21.316.01.01.274
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E8372H-608
- Supported Ver: 21.316.01.02.274
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E8372H-608
- Supported Ver: 21.316.01.03.274
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E8372H-608
- Supported Ver: 21.316.01.04.274
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Imei Repair Command: "at^nvwrex=0,0,16,X X X X X X X X X X X X X X X 0"
- Note: After Patch Flash, User have to Enter "Repar Imei Command" from "Dc Unlocker" & open Home Page of Modem and write New "Wifi Name"
- Model: E5573cs-322
- Supported Ver: 21.318.xx.xx.306
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Supported Ver: 21.323.xx.xx.306
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E8372h-153
- Supported Ver: 21.313.xx.xx.306
- Test Point: YES
- Erase: Yes
- Patch Flash: Yes
- Note: After Patch Flash, User have to Enter "Unlock Command" from "Dc Unlocker" & Update Firmware to which has in modem.
- Model: E8372h-153
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E8372h-153
- Supported Ver: 21.321.xx.xx.306
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
- Model: E5573s-320
- Supported Ver: 21.315.01.00.306
- Test Point: No
- Erase: No
- Patch Flash: Yes
- Model: E5573s-320
- Supported Ver: 21.315.01.01.306
- Test Point: Yes
- Erase: Yes
- Patch Flash: Yes
