10-17-2017, 21:21 | #31 (permalink) |
Freak Poster Join Date: Nov 2016
Member: 2649950 Status: Offline Thanks Meter: 33 | >>Current Task: ZTE>>Qualcomm>>Write Factory Files>>Select Factory Boot >>Getting Info From Factory File,Please Wait... >>Name: ZTE-V811W >>Brand: ZTE >>Device: P821E10 >>Release Version 4.4.2 >>BaseBand CPU: MSM8210 >>Project Version: ZTE_V811W_V1.0 >>Ext Info: ZTE V811W >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Port Found[COM86]. >>Hardware Id:008110e1 >>Selected Boot File is:\!\zte blade m\Qualcomm_Factory_Loader_MSM8x10_Special.mbn >>Waiting for flash programmer to boot. >>Writing modem... >>Status: 13 The data is invalid. Write modem Fail. what can it be? HW problem? |
10-21-2017, 07:31 | #40 (permalink) |
Freak Poster Join Date: Jul 2016 Location: ubauro Distik Ghotki
Member: 2601587 Status: Offline Thanks Meter: 201 | E8231-1s = ver 22.618.17.00.274 erase done patch flash twice done but web not open like dead i request to team please note my post and solve this problem asap ... Thanks in advance... |
10-21-2017, 14:00 | #41 (permalink) |
Crazy Poster Join Date: Jul 2009
Member: 1079316 Status: Offline Thanks Meter: 4 | telenor wingal e8372 608 this frimware unlock Found modem : E8372 Model : Huawei E8372h IMEI : 866280027519983 Serial NR. : R7EDU17804002430 Firmware : 21.327.62.00.1460 Dashboard version : WEBUI_17.100.18.01.1460_RE5 Web UI version : WEBUI_17.100.18.01.1460_RE5 SIM Lock status : Locked (Card Lock) Wrong codes entered : 0 (unlock attempts left : 10) |
10-23-2017, 18:35 | #43 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | Model: E5573cs-609 Supported Ver: 21.318.xx.xx.274 Test Point: Yes Erase: Yes Patch Flash: Yes Unlock Command: at^nvwrex=8268,0,12,1,0,0,0,2,0,0,0, a, 0,0,0 Imei Repair Command: No Need Note: After Patch Flash, User have to Enter "Unlock Command" from "Dc Unlocker" & then Update Firmware to which has in Modem before Erase. repair imie >>Current Task: HUAWEI>>Read Modem Info >> >>Current Port: FC - PC UI Interface (COM5) >> >>Modem Info: >> Manufacturer : E5573Cs-323 >> Firmware Ver. : 21.322.01.00.1430 >> IMEI : 862204031251288 >> SN. : YRY7S17531000714 >> IsoVer. : WEBUI_17.100.15.01.1430_MRE5 >> WebUiVer. : WEBUI_17.100.15.01.1430_MRE5 >> Sim Card Status : Unlocked >> Wrong Codes Counter : 0 (left : 10) >> >>Modem Info Saved Path: C:\Users\scott\Downloads\InfernoTool_UniTool_EXT_V olcano_V1.4.2_20171020\UniTool_Vol_EXT\ModemInfo\E 5573Cs-323__2017-10-24 01_35_21 |
10-26-2017, 22:54 | #44 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Nigeria,Delta
Member: 786852 Status: Offline Thanks Meter: 31 | What about this Modem Firmware Detecting modem : selection : manufacturer - Huawei modems model - Auto detect (recommended) Found Applications port COM86 Found modem : E8231 Model : Huawei E8231 IMEI : 867638021387724 Serial NR. : Z9X7S15C06002054 Firmware : 22.618.13.00.251 Compile date / time : Nov 20 2015 15:41:10 Hardware ver. : CH1E8231SM Dashboard version : WEBUI_17.100.12.00.251_RE5 SIM Lock status : Locked (Card lock) Wrong codes entered : 0 (unlock attempts left : 10) Can it be unlocked ? If yes how can it be unlocked. |
10-28-2017, 15:01 | #45 (permalink) |
Junior Member Join Date: Nov 2008
Member: 901958 Status: Offline Thanks Meter: 1 | Found modem : E5330Bs-2 Model : Huawei E5330 / MTC 424D IMEI : 868988020587363 Serial NR. : T4F7S15928000465 Firmware : 21.210.25.00.274 Compile date / time : Jan 22 2016 10:24:22 Hardware ver. : CH1E5330SM Dashboard version : 16.100.05.00.03 SIM Lock status : Locked (Card lock) Wrong codes entered : 10 (unlock attempts left : 0) after erase and patch with inferno not opening interface in browser just lights blinking. anybody have solution? |
