03-22-2017, 19:28 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: EGYPT Age: 39
Member: 1298774 Status: Offline Sonork: 100.1584126 Thanks Meter: 94 | ZTE Blade s6 MSM8939 FORMAT failed >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Port Found[COM5]. >>Waiting for flash programmer to boot. >>Status: 21 The device is not ready. >>Get Partition Info Fail. >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Port Found[COM5]. >>Formatting... >>Status: 21 The device is not ready. >>Format Fail |
03-23-2017, 05:30 | #2 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
Once try to change your drivers with given drivers (Uninstall old drivers with delete option and install this drivers mannually) https://drive.google.com/file/d/0BxR...ew?usp=sharing First take read info if read info pass then do format, if same error you got again then it's mean atm not supported. If you can provide it's factory file then we can check and add this soon Thank you b/r Team GPG | |
04-01-2017, 22:24 | #3 (permalink) |
Member: 1298774 Status: Offline Sonork: 100.1584126 Thanks Meter: 94 | same prob i think its not supported >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Phone Connect TimeOut. >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Port Found[COM5]. >>Waiting for flash programmer to boot. >>Status: 21 The device is not ready. >>Get Partition Info Fail. |
