Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported WebShop Companies > "DITS" > Gsm Finder > Gsmfinder Pc Version
Old 07-05-2012, 07:02   #1 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: 100.1592878
..::[How TO]Root Samsung Phones[Tutorials]::..
How To Root I9300
[INSTRUCTIONS:]
[Prerequisites:]
Odin V1.85
CF-Root-SGS3-v6.0
Kies for Driver
a Microusb Cable.
[Steps:]
1.Open Odin v1.85.
2.Select CF-Root-SGS3-v6.0.tar in pda(do not extract)
3.Connect your phone in download mode.
4.VOL Down+Power For download mode
5.Vol up For Yes.
6.Connect phone to pc.
7.Click on Start.
8.Wait for Finish flashing.
Congrat I9300 Now Rooted...
Old 07-05-2012, 07:13   #2 (permalink)
Member: 1713856
Sonork: 100.1592878
How To Root S5830I
[INSTRUCTIONS:]
[Prerequisites:]
Root Galaxy Ace S5830i.zip
a Microusb Cable.
[Steps:]
1.Copy the file "Root Galaxy Ace (S5830i/S5839i).zip" to the root folder of your memory card;
2.Shutdown your device;
3.Put your device into Recovery mode;
4.Select "apply update from sdcard" and choose "Root Galaxy Ace (S5830i/S5839i).zip";
5.Select "reboot system now";
6.After reboot phone will be rooted.
Congrat S5830i NOw rooted
Old 07-05-2012, 07:26   #3 (permalink)
Member: 1713856
Sonork: 100.1592878
How To Root I9100 4.0.X.
[INSTRUCTIONS:]
[Prerequisites:]
Odin V1.85
CF-Root-SGS2_UH_UVC_LPK-v5.5-CWM5.zip
Kies for Driver
[Steps:]
1.Unzip the attached CF-Root-xxx-vX.X.zip
2.(USB) Disconnect your phone from your computer
3.Start ODIN
4.Click the PDA button, and select CF-Root-xxx-vX.X.tar
5.Put your phone in download mode
6.(USB) Connect the phone to your computer
7.Make sure repartition is NOT checked
8.Click the START button
9.Wait for the phone to reboot
10.Done
Congrat I9100 Not rooted
Old 07-05-2012, 07:44   #4 (permalink)
Member: 1713856
Sonork: 100.1592878
Universal Gingerbread Root.
Supported Modes:
GT-S5570, GT-S5570B, GT-S5570I, GT-S5570L, GT-S5571 (new), GT-S5660, GT-S5660M, GT-S5660L, GT-S5660V, SHW-M290K (Korean GIO), GT-S5670, GT-S5670B, GT-S5670L, GT-S5830, GT-S5830B, GT-S5830C ,GT-S5830D, GT-S5830i, GT-S5830L, GT-S5830M, GT-S5830T (new) , GT-S5830Z (new), GT-S5839i (new) GT-B7510, GT-B7510B, GT-B7510L, GT-B7800, GT-B5510, GT-B5510B, GT-B5510L, GT-B5512, GT-B5512B. GT-S6102, GT-S6102B (new) , GT-S5300, GT-S5360, GT-S5360B (new), GT-S5360L, GT-S5360T, GT-S5363, GT-S5369, GT-S5690, GT-S5690M (new) GT-S5690L, GT-I8150, GT-I8150B, GT-I5510, GT-I5510B, GT-I5510L, GT-I5510M, GT-I5510T.
[Step:]
1.First enable Unknown sources on your phone (Settings -> Applications -> Unknown sources)
2.Download the universal_gb_root_v20.zip file and put in your SD card
3.Enter in recovery mode,almost all phone enter recovery with vol up+Power.
4.choose "apply update from sdcard"
5.choose the universal_gb_root_v20.zip
6.You will see a message "Install form sdcard complete".
7.Then press on the "reboot system now"
8.When you open SuperSU it will ask you to upgrade the SU binary just press continue your phone will reboot once and you are done!
Thanks to StoneBoyTony for this great info
Old 07-05-2012, 07:54   #5 (permalink)
Member: 1713856
Sonork: 100.1592878
How To Root P7500 Retail 3G
[INSTRUCTIONS:]
[Prerequisites:]
Root.zip
[Steps:]
1. Download this Root.zip file to your tablet and move it to root directory of tablet storage. (you can also download on comp. then transfer to tablet)
2. Reboot tab and go into recovery mode and apply the root.zip you just downloaded.
3. Then reboot
Cograts P7500 Now Rooted.
Old 07-05-2012, 08:41   #6 (permalink)
Member: 1713856
Sonork: 100.1592878
N7000 ICS Install plus rooting.
[INSTRUCTIONS:]
[Prerequisites:]
CWM
SU-Busybox-Installer.zip
SU-Uninstaller-signed.zip
4.0.3 Firmware ZSLPF
Odin V1.85
Kies for Driver
[Steps:Flash]
1.download file and extract
2.select files like in pic.
3.put phone in download mode by press vol down+power and do yes by pres vol up.
4.connect phone to pc and click on start wait for finish.
now phone is ics now we go to root that.
[Step:Root]
1.copy this files in your SDCARD [CWM zip][ SU-Busybox-Installer.zip][ SU-Uninstaller-signed.zip]
2.Reboot to recovery.
3.Choose apply update from external storage. (use vol up/down to select, power to enter)
4.Choose CWM.zip and wait until CWM recovery appear.
5.Choose install zip from sdcard or external SD(Now use touch function to select choice)
6.Choose and Install SU-Busybox-Installer.zip
7.Reboot
Cograts N7000 Now ICS and Rooted
Old 07-05-2012, 09:31   #7 (permalink)
Member: 1713856
Sonork: 100.1592878
How To Root T989 T-Mobile S2.
[INSTRUCTIONS:]
[Prerequisites:]
Odin V1.85
ClockWork Recovery
Superuser+Su
[Step:]
1.Put the Superuser.zip file on your internal SD
2.Take the battery out and place it back.
3.Hold both Vol up + Vol down, and plug the USB cable in.
4.On ODIN, Select the PDA button and browse to the recovery-cwm-hercules.tar.
5.It should flash the file to Recovery and reboot the phone.
6.Take the battery out again and now boot into recovery.
7.Power off phone, unplug USB, Hold Both Vol up + Vol down and Hit power
8.PERFORM NANDROID BACKUP FOR YOUR OWN SAFETY*
9.Select Install zip from sdcard, choose the Superuser .zip and let it finish.
10.Reboot!
Cograts T989 T-Mobile S2 Now Rooted
Old 07-05-2012, 09:59   #8 (permalink)
shahabuddin's Avatar
Member: 407782
Sonork: 100.1586820
How To Root P7510 and T859 Tab 10.1
[INSTRUCTIONS:]
[Prerequisites:]
Odin V1.85
Root.zip
Kies For Driver
[Step:]
1.Power On phone in download Mode by press.
2.Hold the Vol Down button (the left Volume button) and then hold the Power button as well.
3.Press the Vol Up button (the right Volume button) to select Downloading mode.
4.open Odin V1.85 and select file in pda recovery-cwm_4.0.0.4-sam-tab-10.1.tar.md5.
5.connect phone and click on start and wait for finish.
6.On your device, turn off USB Debugging by going to Settings>Applications>Development and unchecking USB debugging.
7.Plug your USB cable back in.
8.copy file Samsung_Galaxy_Tab_10.1_root.zip insdie the device drive folder.
9.Put the device into Recovery mode.
Keep holding until you see two icons. First you'll see the Samsung Galaxy Tab 10.1 logo and then the icons will show up. Let go.
Press the Vol Down button (the left Volume button) to highlight the left icon.
Press the Vol Up button (the right Volume button) to select Recovery mode.
10.You should see that you are in ClockworkMod Recovery. If not, start over
11.Use the volume buttons to highlight "Install zip from SD card" and hit the Power button to select it.
12.Use the volume buttons to highlight "Choose zip from SD card" and hit the Power button to select it.
13.Use the volume buttons to highlight "Samsung_Galaxy_Tab_10.1_root.zip" and hit the Power button to select it.
14.Use the volume buttons to highlight "Yes - Install..." and hit the Power button to select it.
When it finishes, the last line should say "Install from sdcard complete."
15.Use the volume buttons to highlight "*****Go Back*****" and hit the Power button to select it.
16.Hit the Power button to select "reboot system now"
17.Your device will reboot.
Cograts P7510 Now Rooted
Old 07-05-2012, 10:55   #9 (permalink)
Member: 1713856
Sonork: 100.1592878
How To Root I727 and i727R.
[INSTRUCTIONS:]
[Prerequisites:]
Odin V1.85
ClockWork Recovery
Superuser+Su
[Step:]
10.Reboot!
Note:This will root 2.3.5 or 2.3.6 Only.
Cograts I727 Now Rooted
Old 07-05-2012, 12:48   #10 (permalink)
Member: 1713856
Sonork: 100.1592878
How To Root I777
[INSTRUCTIONS:]
[Prerequisites:]
Odin V1.85
GalaxyS2ATTRootZedomax.zip
Kies for Driver
[Steps:]
1.Extract into a folder on your computer the contents of the ZIP file that you downloaded. The package contains everything you need.
2.Turn off your phone completely.
3.Put your phone in Download Mode by holding down the Volume Down key, Volume Up key, and the Power buttons at the same time. Once you see “Warning” displayed on the screen, press the Volume Up key.
4.Run Odin3 on your computer. The program is among the extracted files.
5.Plug your phone into your PC using a USB cable. Odin3 should be able to recognize your phone once you plug the phone into your PC. The ID:COM box in Odin3 will light up in yellow if it properly detects your phone.
6.In Odin3, go to the PDA tab and choose SGH-I777-ATTGalaxyS2RootStockZedomaxKernel.tar.
7.Flash the file by clicking the Start button in Odin3 and wait for the process to finish. You will see a PASS message if the process is successful. If you get a FAIL message, remove and reinsert your battery and start over from step 3.
8.Your phone should reboot automatically and you should already have root and ClockworkMod Recovery installed.
9.Verify that you’ve successfully rooted the phone. Go to Settings > About phone and check whether the Kernel version shows “2.6.35.7_ZedomaxStockKernel”. If it does, then you’re okay.
Cograts I777 Now Rooted
Old 07-05-2012, 13:12   #11 (permalink)
Member: 1713856
Sonork: 100.1592878
How To Root P6200/P6210/SGH-T869 & Galaxy Tab 7.7 P800.
[INSTRUCTIONS:]
[Prerequisites:]
Rootoriginal.zip
Kies For Driver
[Step:]
1.Transfer rootoriginal.zip to the EXTERNAL CARD on Galaxy Tab Plus
2. Turn off the Galaxy Tab Plus
3. Enter Recovery
- Hold Volume UP button + Power Button
- When TAB turns ON, RELEASE POWER BUTTON (Keep Holding Volume UP Button)
- Will Enter Recovery
4. Select install update from EXTERNAL Storage
5. Look for the file root.zip and select it with power button
6. When Finish, REBOOT
Additional
Go to MARKET and INSTALL SUPERUSER... Run this app and Update SU Binary
Go to MARKET and INSTALL BUSYBOX... Run this app and Install your chosen BusyBox version
Cograts P6200/P6210/SGH-T869 & Galaxy Tab 7.7 P800. Now Rooted
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Page generated in 0.36677 seconds with 11 queries
