Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box > Volcano Flash Files
Old 06-30-2015, 12:30   #301 (permalink)
Member: 2142640
hi
Post All Spd Android Pac File 6820,8810
Old 06-30-2015, 12:35   #302 (permalink)
Member: 1640892
Sonork: 100.1651734
Thanks Meter: 25
Download from here
Originally Posted by johnoroo37 View Post
please i need it1452,it1453,it1405
brhttp://downloads.ziddu.com/download/24671083/IT1452-by-Salem.rar.html
baruga
Old 06-30-2015, 12:45   #303 (permalink)
Member: 1640892
Sonork: 100.1651734
Thanks Meter: 25
Download from here
http://http://downloads.ziddu.com/do...Salem.rar.html
Old 07-01-2015, 16:13   #304 (permalink)
obummuo's Avatar
Member: 1849839
Sonork: obummuo
Thanks Meter: 60
Originally Posted by wisdom001 View Post
How to flash bro
Research download or miracle
Thank
Old 07-01-2015, 16:33   #305 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 120
use any of them either Research download or miracle
Old 07-01-2015, 16:43   #306 (permalink)
obummuo's Avatar
Member: 1849839
Sonork: obummuo
Thanks Meter: 60
Used research download. Now d phone has bricked.jus vibrates twice nothing else
It was on google account before
Any solution pls
Old 07-01-2015, 17:24   #307 (permalink)
obummuo's Avatar
Member: 1849839
Sonork: obummuo
Thanks Meter: 60
Is it1503 sc7710 or sc7715
Old 07-01-2015, 18:13   #308 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 120
for pattern lock you should have only flash the user area let me try to upload another it1503 pac tomorrow or next or search forum
Old 07-02-2015, 14:23   #309 (permalink)
obummuo's Avatar
Member: 1849839
Sonork: obummuo
Thanks Meter: 60
That's excatlyl what I did. Fdl1 n Fdl2 with user area. But I always get this, failed: incompatible partition.
Thanks for responses bro
Old 07-02-2015, 20:31   #310 (permalink)
Member: 1079890
Sonork: eddyreal
Thanks Meter: 12
please how can i root itel it1403 4.4.2. i have tried all my root software but no success. the phone is pattern locked, i want to root and wipe with my volcano
Old 07-02-2015, 22:28   #311 (permalink)
Member: 2349975
Thanks Meter: 51
send me a PM on this problem.
The Following User Says Thank You to Feturi For This Useful Post:
Old 07-02-2015, 23:22   #312 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
Arrow
Originally Posted by obummuo View Post
that's excatlyl what i did. Fdl1 n fdl2 with user area. But i always get this, failed: Incompatible partition.
brother flash again but this time uncheck this files
1 nv uncheck
2 nvw uncheck
3 wvn uncheck
4 uncheck
5 uncheck
always uncheck those 5 five lines
count it starting from nv nv1-5lines
then click ok and flash your mobile will boot ok...
The Following User Says Thank You to johnoroo37 For This Useful Post:
Old 07-03-2015, 08:40   #313 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 120
no need root phone follow this step press power button and press volume down immidiately after and when phone display remove hand from power and still press the volume button it will show recovery mode and press volume up.
The Following 2 Users Say Thank You to wisdom001 For This Useful Post:
Old 07-03-2015, 09:21   #314 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 120
(1). Follow this step press power button and press volume down immidiately after and when phone display remove hand from power and still press the volume button it will show recovery mode and press volume up. work on itel: 1403,1403+,1404,1405,1501,1502,1503 and all sc7715 itel for it1701 use volume up instead of down
(2)use volcano box or any other fastboot device, for volcano box open volcano android tool and go to ABD MODE tick shift mode and select bootloader and click start then remove battery from the itel and put it back and switch it on with the itel plug to pc usb port it will reboot to fastboot mode and browse to FASTBOOT in android tool to wipe data,wipe cache and exit fastboot all done. Work on itel: 1400,1401,1500,it1700 and all sc7710 itel phone,if you encounter any problem post here i will help you out.
The Following 4 Users Say Thank You to wisdom001 For This Useful Post:
Old 07-03-2015, 16:25   #315 (permalink)
obummuo's Avatar
Member: 1849839
Sonork: obummuo
Thanks Meter: 60
1 nv uncheck
2 nvw uncheck
3 wvn uncheck
4 uncheck
5 uncheck
bro this is what i get, did i do it right?
thanks
Page generated in 0.27508 seconds with 9 queries
