06-26-2014, 18:26 | #16 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Sri Lanka Age: 34
Member: 1615710 Status: Offline Sonork: 100.1647890 Thanks Meter: 260 | |
The Following User Says Thank You to N.C.Erepola For This Useful Post: |
08-25-2014, 04:09 | #21 (permalink) |
Registered User Join Date: Oct 2005 Location: newzeland Age: 43
Member: 191225 Status: Offline Thanks Meter: 2,097 | new spd flasher updated for china spd anroid phones spd anroid gsm flasher - Download - 4shared - Lords Unlocker |
09-19-2014, 20:17 | #23 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: Tanzania
Member: 14229 Status: Offline Thanks Meter: 135 | Quote:
09-23-2014, 11:07 | #24 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2256277 Status: Offline Thanks Meter: 0 | hi wen i flash 9500 mini with research download tool screen turns white.i doubt if its the file,bcoz on the research download tool Lcd configure bar states that "you wil see nothing until the special ps/userlmg file in mainpage is set & selected."how do i set it or select it |
04-10-2015, 17:59 | #25 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2376992 Status: Offline Thanks Meter: 0 | touch problems on m-horse9500mini hy i got a problem i flashed my m-horse 9500 mini with this file-----6820_2.3.5_c913_jhm_e08_v05_130626-E08-130626-4P after flashing the touch pad doesnt work including the home key and the soft keys |
04-14-2015, 16:34 | #26 (permalink) |
Freak Poster Join Date: Jul 2004 Age: 44
Member: 71526 Status: Offline Thanks Meter: 48 | It is not a big problem with this set - it can be solved in next way: download 1) downlad backup from 1st post, extract archive 2) download from internet "M-horse-9500-mini 6820_2.3.5_c913_jhm_e08_4p_v04_130601.pac" 3) download "UPGRADEDOWNLOAD_R2.9.7006" prapare 1) enable some restrictions in upgradedownload.ini file: ShowOtherPage = 1 CanEdit = 1 CanSelect = 1 then save modifications. 2) run download tool, open pac file: "M-horse-9500-mini 6820_2.3.5_c913_jhm_e08_4p_v04_130601.pac" press settings and find the real files location (where pac file extracted, usually C:\Users\<yourusername>\AppData\Local\Temp\_Downlo adFiles*** , where * are digits (do not close program) 3) copy 3 files "mtd9.boot.img", "mtd10.recovery.img", "mtd11.system.yaffs2.img" from downloaded backup into another place 4) correct 2 files "mtd9.boot.img", "mtd10.recovery.img" sizes acording to C:\Users\<yourusername>\AppData\Local\Temp\_Downlo adFiles*** boot and recovery (possible with winhex or what U like) flashing 1) flash with "M-horse-9500-mini 6820_2.3.5_c913_jhm_e08_4p_v04_130601.pac" not modified file (LCD must show, sounds must be, but touch will not work) push "stop" button in the downloader, but do not close. 2) in settings main tab replace boot, recovery and system by double klicking on path with your prepared files path. 3) in settings "option" tab check "reset to normal" 4) press "ok" button press "download/flash" button 5) phone must be off , hold volume down on phone and put usb cable Model on sticker: M-Horse 9500 mini, PCB: C913_v1.02_PCB(130111) I've repaired this fcuking set in this way... Br Shadowman |
09-22-2015, 09:58 | #27 (permalink) |
Major Poster Join Date: Oct 2013 Location: Zimbabwe
Member: 2044092 Status: Offline Thanks Meter: 0 | can u help pliz i have this m horse i9500 mini but cant run with all of my pac files, i think its new version, its pattern locked, i have came across with a number of these phones, any help |
11-05-2015, 10:59 | #28 (permalink) | |
Insane Poster Join Date: Apr 2012
Member: 1742810 Status: Offline Thanks Meter: 7 | Quote:
