Sprd com enumerator driver problem in windows 7 I have installed windows 7 in my PC just two days ago. And then Volcano2.8.3 and new drivers for spd. When I detect phone in usb mode it detects the phone successfully as it showing in attached image but when I try to read flash it does not connect. And In Device Manager shows "SPRD COM ENUMERATOR" in yellow color. when I try to update the 'sprd com enumerator' it shows the driver is already up to date. Handset is ok. I have to read user code only. SO WHERE IS THE PROBLEM ? HOW TO FIX IT ? SEE IMAGE........ http://s1372.photobucket.com/user/ja...tml?sort=3&o=0http://i1372.photobucket.com/albums/...g?t=1416756296 http://s1372.photobucket.com/user/ja...tml?sort=3&o=0 http://i1372.photobucket.com/albums/...g?t=1416756257 I would use XP and did not face any problem like this before. |
https://www.4shared.com/zip/-z-BLC67...R_MOBILES.html |
Problem Solved..............Thanks to YMS-RYK-http://forum.gsmhosting.com/vbb/cust...r1489718_1.gif |
my problem also solved..........................thanks |
my problem also solved...windows 7..........thanks rezaul mobile servising senter dhaka |
Update solved problem... using windows 7.... Thank you verry much... |
my proble solved thanks for this |
Thankx my proble solved thanks for this |
Problem Solved..............Thanks |
thnks my problem solve to |
Link not work bro new link this driver plzzzz |
link working Problem Solved,,Thanks |
Problem solved!!! Thanks a lot!!! |
