Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box > Volcano Flash Files
Old 11-23-2014, 16:37   #1 (permalink)
pradeep yadav's Avatar
Member: 1289553
Thanks Meter: 57
Sprd com enumerator driver problem in windows 7
I have installed windows 7 in my PC just two days ago.
And then Volcano2.8.3 and new drivers for spd.
When I detect phone in usb mode it detects the phone successfully as it showing in attached image but when I try to read flash it does not connect.
And In Device Manager shows "SPRD COM ENUMERATOR" in yellow color.
when I try to update the 'sprd com enumerator' it shows the driver is already up to date.
Handset is ok.
I have to read user code only.
SO WHERE IS THE PROBLEM ?
HOW TO FIX IT ?
SEE IMAGE........
I would use XP and did not face any problem like this before.
The Following 4 Users Say Thank You to pradeep yadav For This Useful Post:
Old 11-23-2014, 17:25   #2 (permalink)
YMS-RYK's Avatar
Member: 1489718
Sonork: 100.1652829 QQ 3237590752
Thanks Meter: 1,495
Handset is ok.
HOW TO FIX IT ?
SEE IMAGE........
TRY THIS DRIVER AND POST RESULT
https://www.4shared.com/zip/-z-BLC67...R_MOBILES.html
The Following 34 Users Say Thank You to YMS-RYK For This Useful Post:
Old 11-24-2014, 07:24   #3 (permalink)
Member: 1289553
Thanks Meter: 57
Problem Solved..............Thanks to YMS-RYK-
The Following 5 Users Say Thank You to pradeep yadav For This Useful Post:
Old 12-25-2014, 10:39   #4 (permalink)
Member: 562003
Thanks Meter: 42
my problem also solved..........................thanks
The Following User Says Thank You to zaka_53 For This Useful Post:
Old 04-14-2015, 05:13   #5 (permalink)
Member: 1420516
Thanks Meter: 2
my problem also solved...windows 7..........thanks rezaul mobile servising senter dhaka
The Following User Says Thank You to rezaul1234 For This Useful Post:
Old 06-12-2015, 05:49   #6 (permalink)
Member: 1326389
Thanks Meter: 2
Update solved problem... using windows 7.... Thank you verry much...
The Following User Says Thank You to jhoe_09 For This Useful Post:
Old 09-22-2015, 10:49   #7 (permalink)
Member: 2090479
Sonork: 100.1648908
Thanks Meter: 4
my proble solved
thanks for this
The Following User Says Thank You to linax888 For This Useful Post:
Old 10-07-2015, 06:35   #8 (permalink)
Member: 1555233
Thanks Meter: 2,192
Thankx
my proble solved
thanks for this
The Following User Says Thank You to amjadnona For This Useful Post:
Old 05-30-2016, 10:20   #9 (permalink)
Member: 546501
Old 06-17-2016, 07:04   #10 (permalink)
Member: 1118670
Thanks Meter: 6
thnks my problem solve to
Old 06-17-2016, 22:17   #11 (permalink)
Member: 206012
Thanks Meter: 7
Link not work bro new link this driver plzzzz
Old 07-09-2016, 09:31   #12 (permalink)
Member: 636881
Thanks Meter: 8
link working
Problem Solved,,Thanks
Old 07-28-2016, 18:15   #13 (permalink)
Member: 1361504
Thanks Meter: 16
Originally Posted by YMS-RYK View Post
thanks brother really this driver work for me...!
Old 08-18-2016, 04:56   #14 (permalink)
Member: 952568
Sonork: yoesazel
Smile
Problem solved!!! Thanks a lot!!!
The Following User Says Thank You to yoesazel For This Useful Post:
Old 08-29-2016, 20:13   #15 (permalink)
Member: 402816
The Following User Says Thank You to slen79 For This Useful Post:
Page generated in 0.21693 seconds with 8 queries
