SmartSamBox SmartSamBox official support area |
05-21-2013, 09:35 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: India Age: 28
Member: 237417 Status: Offline Thanks Meter: 56 | Samsung S3353 Flashing Error In SmartSam Power off phone, press * and connect by USB Wait for device... ok Device synchronize... ok Injecting EBL... ok Boot-loader is active EBL version: 6180_Bootloader_10.0_MKEYSKEY 10.0 Boot mode is: BB Baud rate set to 921600... ok Get flash id... ok Flash ID is: 220800EC Boot process finished Start downloading item "BOOT CORE SLB:dwdtoolsrc/bootcore/make/.output/XMM6180_EHS2AGR_CATFISH_ROU_TREVI/fls/psi_flash.fls" from file "E:\samsung\S3353\S3353DXJK2_psi_flash.fls" Sending sec-pack... ok Use flash pre-erase... ok Sending data... ok Sending end-pack... ok Done! Start downloading item "CODE:catfish.fls" from file "E:\samsung\S3353\S3353DXJK2_BSY_bin.fls" Sending sec-pack... ok Use flash pre-erase... ok Sending data... fail |
05-21-2013, 10:42 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: India\China
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks Meter: 948 | Pls select baudrate 921600 & tick "ERASE ALL FLASH" then flashed again. Wbr gsm_links Smartsam Box Team Last edited by gsm_links; 05-21-2013 at 12:56. |
05-21-2013, 15:58 | #3 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: GSM World!! Age: 35
Member: 1530237 Status: Offline Sonork: 100.1614868 Thanks Meter: 5,598 | Quote:
friend are performing poorly the flashing process! You must select the option "ERASE ALL FLASH" & Really the whole process complete successfully! For Your Help! Please Check Out The Following Link http://forum.gsmhosting.com/vbb/f729...eo-hd-1659259/ !!Video Tutorial - How to Flash One Phone Infineon Family!! Br, resident | |
The Following User Says Thank You to resident2011 For This Useful Post: |
