07-07-2012, 18:22 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | 1202 not connecting I have 1202 set with show NOKIA & goes off problem. I don't have working 1202 cable for this set. I use DCT4 01 Jig for this set & i use this pinout. TX RX O O O O O Vpp Mbus Gnd Please correct if i wrong. |
07-08-2012, 02:07 | #2 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
yes jig Number is Correct , which box you are using .. please Check swith in jig . must be ufs or jaf , if your box is atf , mxbox, ufs , cyclone which box you are using | |
07-08-2012, 09:06 | #3 (permalink) | |
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
Also i am using with all but not work. Using UFS - ATF - CYCLONE - Also when i use UFS the switch is located to UFS printed. | |
07-08-2012, 09:19 | #4 (permalink) | |
Anyway Where are you from , which country ? | |
07-10-2012, 17:52 | #5 (permalink) | |
I have try to change the bsi value but not work for me. What fix value i set for bsi ? & other switch ? Is bsi value different for different model ? | |
07-11-2012, 19:57 | #6 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | yes , it's differ for model wise . anyway u try 5.1k or 7.5k bsi value. use jig no =DCT4-01 , clean d fbus pads on phone . if still same try to check another 1202 or 1661 or 1616 , these all models have same pinout. |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
Nokia Datasuite Connection Failure | Judesp | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-27-1999 09:36 |
